- From: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Difference between [setoid_rewrite at 1] and [setoid_rewrite]?
- Date: Mon, 10 Mar 2014 15:37:35 +0100
Hi,
As suggested by Cedric it might fail because just the first occurrence can be rewritten,
otherwise it’s probably a bug indeed. Note that rewrite at has a different semantic (it’s counting
occurrences of the first complete unification appearing in the goal). The bug tracker is
inaccessible right now…
— Matthieu
Le 10 mars 2014 à 09:34, Jason Gross <jasongross9 AT gmail.com> a écrit :
Hi,Can someone explain to me the difference between [setoid_rewrite ... at 1] and [setoid_rewrite ...]? In particular, why might the first succeed when the second fails? (This seems to me to be a bug, so I reported it, with a test case, at https://coq.inria.fr/bugs/show_bug.cgi?id=3253.)Thanks,Jason
- [Coq-Club] Difference between [setoid_rewrite at 1] and [setoid_rewrite]?, Jason Gross, 03/10/2014
- Re: [Coq-Club] Difference between [setoid_rewrite at 1] and [setoid_rewrite]?, Cedric Auger, 03/10/2014
- Re: [Coq-Club] Difference between [setoid_rewrite at 1] and [setoid_rewrite]?, Matthieu Sozeau, 03/10/2014
- Re: [Coq-Club] Difference between [setoid_rewrite at 1] and [setoid_rewrite]?, Jason Gross, 03/11/2014
