- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Difference between [setoid_rewrite at 1] and [setoid_rewrite]?
- Date: Tue, 11 Mar 2014 13:49:39 -0400
That seems to be the case in this instance; if I use [set] to remove all the evars from the goal, then it magically works again without the [at 1]. However, I still can't get setoid_rewrite to work on the underlying problem (even with [at 1]), which is at https://coq.inria.fr/bugs/show_bug.cgi?id=3254 and also https://gist.github.com/JasonGross/9491068.
The error message is
Error:
Tactic failure:setoid rewrite failed: Unable to satisfy the rewriting constraints.
Unable to satisfy the following constraints:
EVARS:
?267==[Rep0 MethodNames0 UnbundledMethods0 idx r_n n H
|- ProperProxy ?265 ?224] (internal placeholder)
?266==[Rep0 MethodNames0 UnbundledMethods0 idx r_n n H
(do_subrelation:=do_subrelation)
|- Proper (?263 ==> ?265 ==> flip impl) refine]
?265==[Rep0 MethodNames0 UnbundledMethods0 idx r_n n H
|- relation (Comp (Rep0 * cod idx))] (internal placeholder)
?264==[Rep0 MethodNames0 UnbundledMethods0 idx r_n n H
|- Proper (pointwise_relation (Rep0 * cod idx) refine ==> ?263)
(Bind (UnbundledMethods0 idx r_n n))] (internal placeholder)
?263==[Rep0 MethodNames0 UnbundledMethods0 idx r_n n H
?224==[Rep0 MethodNames0 UnbundledMethods0 idx r_n n
|- Comp (Rep0 * cod idx)] (underscore)
At a glance, it seems like it might be failing because it's inferred [flip impl] where it should have inferred [impl], but I'm not really sure.
-Jason
On Mon, Mar 10, 2014 at 10:37 AM, Matthieu Sozeau <matthieu.sozeau AT gmail.com> wrote:
Hi,As suggested by Cedric it might fail because just the first occurrence can be rewritten,otherwise it’s probably a bug indeed. Note that rewrite at has a different semantic (it’s countingoccurrences of the first complete unification appearing in the goal). The bug tracker isinaccessible right now…— MatthieuLe 10 mars 2014 à 09:34, Jason Gross <jasongross9 AT gmail.com> a écrit :Hi,Can someone explain to me the difference between [setoid_rewrite ... at 1] and [setoid_rewrite ...]? In particular, why might the first succeed when the second fails? (This seems to me to be a bug, so I reported it, with a test case, at https://coq.inria.fr/bugs/show_bug.cgi?id=3253.)Thanks,Jason
- [Coq-Club] Difference between [setoid_rewrite at 1] and [setoid_rewrite]?, Jason Gross, 03/10/2014
- Re: [Coq-Club] Difference between [setoid_rewrite at 1] and [setoid_rewrite]?, Cedric Auger, 03/10/2014
- Re: [Coq-Club] Difference between [setoid_rewrite at 1] and [setoid_rewrite]?, Matthieu Sozeau, 03/10/2014
- Re: [Coq-Club] Difference between [setoid_rewrite at 1] and [setoid_rewrite]?, Jason Gross, 03/11/2014
