- From: Francesco Zappa Nardelli <francesco.zappa_nardelli AT inria.fr>
- To: coq-club AT inria.fr
- Cc: Peter.Sewell AT cl.cam.ac.uk
- Subject: Re: [Coq-Club] Formalization of Ott alpha-equivalence?
- Date: Wed, 12 Mar 2014 21:14:43 +0100
Hi Mitch,
The JFP version (JFP 2010) of the Ott paper (ICFP 2007) contains a worked-out definition of alpha-equivalence for terms whose binding structures are defined in Ott.
That semantics of the binding structures of Ott is described in detail
in the note:
http://www.cl.cam.ac.uk/~pes20/ott/bind-doc.pdf
with definitions formalised in Ott itself and paper proofs of some
sanity properties. It should be easy to generate a Coq version of the
definitions - we did some work towards that at the time, and we could
give you the Ott sources if you want. But we didn't do mechanised
proofs of the metatheory.
-francesco
signature.asc
Description: Message signed with OpenPGP using GPGMail
- [Coq-Club] Formalization of Ott alpha-equivalence?, Mitchell Wand, 03/11/2014
- Re: [Coq-Club] Formalization of Ott alpha-equivalence?, Francesco Zappa Nardelli, 03/12/2014
- Re: [Coq-Club] Formalization of Ott alpha-equivalence?, Mitchell Wand, 03/12/2014
- Re: [Coq-Club] Formalization of Ott alpha-equivalence?, Frédéric Blanqui, 03/12/2014
