- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] This clause is redundant error
- Date: Tue, 18 Mar 2014 11:13:37 +0100
What I meant is that in pattern matching you can only refer to
constructors of the inductive type. The following code works:
Inductive st :Set:= q0 | q1 |q2 .
Inductive acts:Set:=pred(p:nat)|event(e:bool).
Function trans (q:st)(x:acts) :list st :=
match q, x with
| q0, pred 1 => cons q1 nil
| q1, pred 2 => cons q0 nil
| q1, event true => cons q2 nil
| _,_ => nil (A:=_)
end.
On Tue, Mar 18, 2014 at 11:08 AM, Djamila Baroudi
<baroudi.d7 AT gmail.com>
wrote:
> hello, you mean that i should write for example this:
>>> Definition a :acts:=pred(1).
>>> Definition b:acts:=pred(2).
>>> Definition c:acts:=event(true).
>>> match q, x with
>>> | q0, a => cons q1 nil
>>> | q1, b => cons q0 nil
>>> | q1, c => cons q2 nil
>>> | _,_ => nil (A:=_)
>>> end.
> but with this code i have always a same error.
> thanks for your informations.
> 2014-03-18 10:54 GMT+01:00 Beta Ziliani
> <beta AT mpi-sws.org>:
>> Sorry, forgot to mention that Coq is treating a,b,c in each pattern
>> matching clause as variables, and this is why is giving you the error.
>> On Tue, Mar 18, 2014 at 10:52 AM, Beta Ziliani
>> wrote:
>> > Basically your definitions a, b, c of acts are not constructors for
>> > the inductive type acts, which is what Coq expects (as most languages)
>> > in the match. Also, take into account that writing
>> > Definition a : acts.
>> > is opening a goal to fill: what is a? Probably what you meant is
>> > Axiom a : acts.
>> > (but be careful with axioms!).
>> > Hope it helps,
>> > Beta
>> > On Tue, Mar 18, 2014 at 10:42 AM, Djamila Baroudi
>> > wrote:
>> >> hello,
>> >> i have a problem with definition of an automaton, an error was shown
>> >> when i
>> >> create this code:
>> >> (*automate*)
>> >> Record automaton :Type:=
>> >> mk_auto {
>> >> states : Set;
>> >> actions :Set;
>> >> initial : states;
>> >> transitions : states -> actions -> list states
>> >> (*States*)
>> >> Definition a :acts.
>> >> Definition b:acts.
>> >> Definition c:acts.
>> >> match q, x with
>> >> | _,_ => nil (A:=_)
>> >> end.
>> >> the error was:
>> >> Error: This clause is redundant. (underlined this clause " | q1, c =>
>> >> cons
>> >> q2 nil")
>> >> Thanks.
>> >> Mlle Djamila Baroudi
>> >> Faculté des Sciences Exactes et Informatique,
>> >> Université de Mostaganem,
>> >> 27000 Mostaganem, Algérie.
- [Coq-Club] This clause is redundant error, Djamila Baroudi, 03/18/2014
- Re: [Coq-Club] This clause is redundant error, Beta Ziliani, 03/18/2014
- Re: [Coq-Club] This clause is redundant error, Djamila Baroudi, 03/18/2014
