coq-club - Re: [Coq-Club] This clause is redundant error
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] This clause is redundant error
  • Date: Tue, 18 Mar 2014 11:23:30 +0100
thanks a lot.
2014-03-18 11:13 GMT+01:00 Beta Ziliani <beta AT mpi-sws.org>:
What I meant is that in pattern matching you can only refer to
constructors of the inductive type.  The following code works:
Inductive st :Set:= q0 | q1 |q2 .
Inductive acts:Set:=pred(p:nat)|event(e:bool).
Function trans (q:st)(x:acts) :list st :=
match q, x with
  | q0, pred 1 =>  cons q1 nil
  | q1, pred 2 =>  cons q0 nil
  | q1, event true =>  cons q2 nil
  | _,_ =>    nil (A:=_)
end.
On Tue, Mar 18, 2014 at 11:08 AM, Djamila Baroudi <baroudi.d7 AT gmail.com> wrote:
> hello, you mean that i should write for example this:
>>>     Definition a :acts:=pred(1).
>>>     Definition b:acts:=pred(2).
>>>     Definition c:acts:=event(true).
>>>     match q, x with
>>>       | q0, a =>  cons q1 nil
>>>       | q1, b =>  cons q0 nil
>>>       | q1, c =>  cons q2 nil
>>>       | _,_ =>    nil (A:=_)
>>>     end.
> but with this code i have always a same error.
> thanks for your informations.
> 2014-03-18 10:54 GMT+01:00 Beta Ziliani <beta AT mpi-sws.org>:
>> Sorry, forgot to mention that Coq is treating a,b,c in each pattern
>> matching clause as variables, and this is why is giving you the error.
>> On Tue, Mar 18, 2014 at 10:52 AM, Beta Ziliani <beta AT mpi-sws.org> wrote:
>> > Basically your definitions a, b, c of acts are not constructors for
>> > the inductive type acts, which is what Coq expects (as most languages)
>> > in the match.  Also, take into account that writing
>> > Definition a : acts.
>> > is opening a goal to fill: what is a?  Probably what you meant is
>> > Axiom a : acts.
>> > (but be careful with axioms!).
>> > Hope it helps,
>> > Beta
>> > On Tue, Mar 18, 2014 at 10:42 AM, Djamila Baroudi <baroudi.d7 AT gmail.com>
>> > wrote:
>> >> hello,
>> >> i have a problem with definition of an automaton, an error was shown
>> >> when i
>> >> create this code:
>> >>     (*automate*)
>> >>     Record automaton :Type:=
>> >>     mk_auto {
>> >>        states : Set;
>> >>        actions :Set;
>> >>        initial : states;
>> >>        transitions : states -> actions -> list states
>> >>     (*States*)
>> >>     Definition a :acts.
>> >>     Definition b:acts.
>> >>     Definition c:acts.
>> >>     match q, x with
>> >>       | _,_ =>    nil (A:=_)
>> >>     end.
>> >> the error was:
>> >> Error: This clause is redundant. (underlined this clause " | q1, c =>
>> >> cons
>> >> q2 nil")
>> >> Thanks.
>> >> Mlle Djamila Baroudi
>> >> Faculté des Sciences Exactes et Informatique,
>> >> Université de Mostaganem,
>> >> 27000 Mostaganem, Algérie.
