coq-club - [Coq-Club] "as <_ or unused variable in the return type> in … return …" pattern matching
  • To: coq-club AT inria.fr
  • Subject: [Coq-Club] "as <_ or unused variable in the return type> in … return …" pattern matching
  • Date: Fri, 21 Mar 2014 10:13:55 +0100
Hi all, today I found a situation where I had to use a "match … as _
in … return …" instead of a "match … as <some name used in the returned
type> in … return …" or a "match … in … return …".
I used to believe that "as _" was the default when not needing to bind
the pattern matched expression to the result type.
Is this a new behavior or something I never noticed?
(To be honest, it is not that often that I wish the pattern matched
expression not to be bound to the return type, so the current behavior
does not annoy me much. Still, I am curious of the answer.)
I use a rather old version of Coq (a trunk version from October 2012),
so things may have changed since.
Fixpoint ord (n : nat) : Type :=
match n with
| O => Empty_set
| S n => option (ord n)
end.
Inductive T (n : nat) : Type :=
| Var : ord n -> T n
| Fun : T (S n) -> T n
| App : T n -> T n -> T n
Inductive redex (n : nat) : T n -> Type :=
| ARedex (u : T (S n)) : redex (S n) u -> redex n (Fun n u)
| LRedex (u v : T n) : redex n u -> redex n (App n u v)
| RRedex (u v : T n) : redex n v -> redex n (App n u v)
| BRedex (u : T (S n)) (v : T n) : redex n (App n (Fun n u) v)
Inductive VarRedex (n : nat) (o : ord n) : redex n (Var n o) -> Type := .
Definition vredex n o r : VarRedex n o r :=
match r as _ (*Woo, first time I have to put an underscore here*)
in redex _ t return match t with Var _ => VarRedex n o r | _ => unit end
with ARedex _ _ | LRedex _ _ _ | RRedex _ _ _ | BRedex _ _ => tt end.
