Re: [Coq-Club] "as <_ or unused variable in the return type> in ... return ..." pattern matching
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] "as <_ or unused variable in the return type> in ... return ..." pattern matching
- Date: Fri, 21 Mar 2014 03:49:38 -0400
Coq seems to be interpreting "match r in ..." as "match r as r in ...". The following version of vredex works:
Definition vredex n o r (r' := r) : VarRedex n o r :=
match r
in redex _ t return match t with Var _ => VarRedex n o r' | _ => unit end
with ARedex _ _ | LRedex _ _ _ | RRedex _ _ _ | BRedex _ _ => tt end.
Perhaps someone else can elaborate on why this is the case.
-Jason
On Fri, Mar 21, 2014 at 5:13 AM, AUGER Cédric <sedrikov AT gmail.com> wrote:
Hi all, today I found a situation where I had to use a "match … as _
in … return …" instead of a "match … as <some name used in the returned
type> in … return …" or a "match … in … return …".
I used to believe that "as _" was the default when not needing to bind
the pattern matched _expression_ to the result type.
Is this a new behavior or something I never noticed?
(To be honest, it is not that often that I wish the pattern matched
_expression_ not to be bound to the return type, so the current behavior
does not annoy me much. Still, I am curious of the answer.)
I use a rather old version of Coq (a trunk version from October 2012),
so things may have changed since.
Fixpoint ord (n : nat) : Type :=
match n with
| O => Empty_set
| S n => option (ord n)
end.
Inductive T (n : nat) : Type :=
| Var : ord n -> T n
| Fun : T (S n) -> T n
| App : T n -> T n -> T n
Inductive redex (n : nat) : T n -> Type :=
| ARedex (u : T (S n)) : redex (S n) u -> redex n (Fun n u)
| LRedex (u v : T n) : redex n u -> redex n (App n u v)
| RRedex (u v : T n) : redex n v -> redex n (App n u v)
| BRedex (u : T (S n)) (v : T n) : redex n (App n (Fun n u) v)
Inductive VarRedex (n : nat) (o : ord n) : redex n (Var n o) -> Type := .
Definition vredex n o r : VarRedex n o r :=
match r as _ (*Woo, first time I have to put an underscore here*)
in redex _ t return match t with Var _ => VarRedex n o r | _ => unit end
- [Coq-Club] "as <_ or unused variable in the return type> in … return …" pattern matching, AUGER Cédric, 03/21/2014
- Re: [Coq-Club] "as <_ or unused variable in the return type> in ... return ..." pattern matching, Jason Gross, 03/21/2014
