[Coq-Club] Mixing Inductive and CoInductive constructors/destructors in the same type
- From: Jean-Baptiste Jeannin <jeannin AT cs.cornell.edu>
- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Cc: Dexter Kozen <kozen AT cs.cornell.edu>, Konstantinos Mamouras <mamouras AT cs.cornell.edu>
- Subject: [Coq-Club] Mixing Inductive and CoInductive constructors/destructors in the same type
- Date: Thu, 27 Mar 2014 14:55:46 -0400
- Accept-language: en-US
- Acceptlanguage: en-US
Hi,
I am trying to define a type with both inductive constructors and coinductive constructors (really destructors).
With the [Inductive] keyword, I can define a type with all constructors inductive, as in:
Inductive list: Type:=
| LNil : list
| LCons : nat -> list -> list.
and similarly with the [CoInductive] keyword, I can define a type with all constructors coinductive, as in:
CoInductive stream : Type :=
| SCons : nat -> stream -> stream.
If I want some constructors to be inductive and others to be coinductive, an idea I had was to use two mutually recursive types, with a construct akin to:
CoInductive even_list : Set :=
| ENil : even_list
| ECons : nat -> odd_list -> even_list
with odd_list : Set :=
| OCons : nat -> even_list -> odd_list.
But I can't seem to make odd_list just [Inductive], while keeping even_list [CoInductive]. Is there any way I could do this? Or any other way to mix Inductive and CoInductive constructors?
(examples taken or inspired from http://adam.chlipala.net/cpdt/html/Coinductive.html and http://adam.chlipala.net/cpdt/html/InductiveTypes.html)
Thank you,
Jean-Baptiste
- [Coq-Club] Mixing Inductive and CoInductive constructors/destructors in the same type, Jean-Baptiste Jeannin, 03/27/2014
- Re: [Coq-Club] Mixing Inductive and CoInductive constructors/destructors in the same type, Kristopher Micinski, 03/27/2014
- Re: [Coq-Club] Mixing Inductive and CoInductive constructors/destructors in the same type, Andrew Hirsch, 03/27/2014
- Re: [Coq-Club] Mixing Inductive and CoInductive constructors/destructors in the same type, Altenkirch Thorsten, 03/28/2014
- Re: [Coq-Club] Mixing Inductive and CoInductive constructors/destructors in the same type, Dexter Kozen, 03/28/2014
- Re: [Coq-Club] Mixing Inductive and CoInductive constructors/destructors in the same type, Jean-Baptiste Jeannin, 03/28/2014
- Re: [Coq-Club] Mixing Inductive and CoInductive constructors/destructors in the same type, Andreas Abel, 03/30/2014
- Re: [Coq-Club] Mixing Inductive and CoInductive constructors/destructors in the same type, Kristopher Micinski, 03/29/2014
