Re: [Coq-Club] Mixing Inductive and CoInductive constructors/destructors in the same type
- To: Altenkirch Thorsten <psztxa AT exmail.nottingham.ac.uk>
- Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>, Konstantinos Mamouras <mamouras AT cs.cornell.edu>, Andrew Hirsch <akh95 AT cornell.edu>, Kristopher Micinski <krismicinski AT gmail.com>, Jean-Baptiste Jeannin <jeannin AT cs.cornell.edu>
- Subject: Re: [Coq-Club] Mixing Inductive and CoInductive constructors/destructors in the same type
- Date: Fri, 28 Mar 2014 08:28:22 -0400
- Accept-language: en-US
- Acceptlanguage: en-US
Hi Thorsten,
That's exactlly what we wanted, except instead
of 'gets' and 'puts' we have something else, but we
wanted exactly that behavior.
Thanks!
Dexter
On Mar 28, 2014, at 6:48 AM, Altenkirch Thorsten
wrote:
> There are many examples of inductive – coinductive definitions. My favorite
> one is Stream processors:
> data SP (I O : Set) : Set where
> get : (I -> SP I O) -> SP I O
> put : O -> \infty (SP I O) -> SP I O
> The idea is that you can have only finitely many gets between any two puts
> but you can have infinitely many puts. In Agda you can achieve this by
> simply putting the \infty symbol in front of the recursive occurrence of
> the type. In Coq that can be achieved by a hack by Tarmo Uustalu and Keiko
> Nakata.
> Hence in Agda your type could be translated as
> data even_list : Set
> data odd_list : Set
> data even_list where
> ENil : even_list
> ECons : nat -> odd_list -> even_list
> data odd_list : Set
> OCons : nat -> \infty even_list -> odd_list.
> However, in a way this is a bad example because it doesn't really matter
> wether one or both constructors are coinductive.
> Cheers,
> Thorsten
> See
> Subtyping, Declaratively - An Exercise in Mixed Induction and Coinduction
> http://www.cs.nott.ac.uk/~txa/publ/danielsson-altenkirch-subtyping.pdf
> Termination Checking Nested Inductive and Coinductive Types
> http://www.cs.nott.ac.uk/~txa/publ/InvertedQuantifiers.pdf
> From: Jean-Baptiste Jeannin
> Reply-To:
> Date: Thu, 27 Mar 2014 18:55:46 +0000
> To:
> Cc: Dexter Kozen
> <kozen AT cs.cornell.edu>,
> Subject: [Coq-Club] Mixing Inductive and CoInductive
>> Hi,
>> I am trying to define a type with both inductive constructors and
>> coinductive constructors (really destructors).
>> With the [Inductive] keyword, I can define a type with all constructors
>> inductive, as in:
>> Inductive list: Type:=
>> | LNil : list
>> | LCons : nat -> list -> list.
>> and similarly with the [CoInductive] keyword, I can define a type with all
>> constructors coinductive, as in:
>> CoInductive stream : Type :=
>> | SCons : nat -> stream -> stream.
>> If I want some constructors to be inductive and others to be coinductive,
>> an idea I had was to use two mutually recursive types, with a construct
>> akin to:
>> CoInductive even_list : Set :=
>> | ENil : even_list
>> with odd_list : Set :=
>> | OCons : nat -> even_list -> odd_list.
>> But I can't seem to make odd_list just [Inductive], while keeping
>> even_list [CoInductive]. Is there any way I could do this? Or any other
>> way to mix Inductive and CoInductive constructors?
>> (examples taken or inspired from
>> http://adam.chlipala.net/cpdt/html/Coinductive.html and
>> http://adam.chlipala.net/cpdt/html/InductiveTypes.html)
>> Thank you,
>> Jean-Baptiste
> This message and any attachment are intended solely for the addressee and
> may contain confidential information. If you have received this message in
> error, please send it back to me, and immediately delete it. Please do
> not use, copy or disclose the information contained in this message or in
> any attachment. Any views or opinions expressed by the author of this
> email do not necessarily reflect the views of the University of Nottingham.
> This message has been checked for viruses but the contents of an attachment
> may still contain software viruses which could damage your computer system,
> you are advised to perform your own checks. Email communications with the
> University of Nottingham may be monitored as permitted by UK legislation.
- [Coq-Club] Mixing Inductive and CoInductive constructors/destructors in the same type, Jean-Baptiste Jeannin, 03/27/2014
- Re: [Coq-Club] Mixing Inductive and CoInductive constructors/destructors in the same type, Kristopher Micinski, 03/27/2014
- Re: [Coq-Club] Mixing Inductive and CoInductive constructors/destructors in the same type, Andrew Hirsch, 03/27/2014
- Re: [Coq-Club] Mixing Inductive and CoInductive constructors/destructors in the same type, Altenkirch Thorsten, 03/28/2014
- Re: [Coq-Club] Mixing Inductive and CoInductive constructors/destructors in the same type, Dexter Kozen, 03/28/2014
- Re: [Coq-Club] Mixing Inductive and CoInductive constructors/destructors in the same type, Jean-Baptiste Jeannin, 03/28/2014
- Re: [Coq-Club] Mixing Inductive and CoInductive constructors/destructors in the same type, Andreas Abel, 03/30/2014
- Re: [Coq-Club] Mixing Inductive and CoInductive constructors/destructors in the same type, Kristopher Micinski, 03/29/2014
