- From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] coqdoc: how do I make a keyword an identifier?
- Date: Tue, 8 Apr 2014 11:01:38 -0400
While waiting for a better solution, you could do the following hack in your .v file:
(** #<a name="wf"></a># *)
Inductive wf : process -> Prop :=
Coqdoc's html output should then be what you wanted.
-- Abhishek
http://www.cs.cornell.edu/~aa755/On Tue, Apr 8, 2014 at 8:50 AM, Alan Schmitt <alan.schmitt AT polytechnique.org> wrote:
Hello,
I've put the coqdoc-generated version of a development online, and I now
want to link to some parts of it. Unfortunately, there is one link to an
inductive that does not work, probably because its name is "wf".
More precisely, in the development, I have:
--8<---------------cut here---------------start------------->8---
--8<---------------cut here---------------end--------------->8---
Looking at the generated html, I see that "wf" is treated as a keyword
and does not have a name anchor:
<span class="id" type="keyword">Inductive</span> <span class="id" type="keyword">wf</span> : <a class="idref" href=""HOC01Defs.html#process"><span" class="id" type="inductive">process</span></a> -> <span class="id" type="keyword">Prop</span> :=<br/>
Is there a way to tell coqdoc that wf is an identifier and not
a keyword?
Thanks,
Alan
- [Coq-Club] coqdoc: how do I make a keyword an identifier?, Alan Schmitt, 04/08/2014
- Re: [Coq-Club] coqdoc: how do I make a keyword an identifier?, Abhishek Anand, 04/08/2014
- Re: [Coq-Club] coqdoc: how do I make a keyword an identifier?, Alan Schmitt, 04/09/2014
