- From: Alan Schmitt <alan.schmitt AT polytechnique.org>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] coqdoc: how do I make a keyword an identifier?
- Date: Wed, 09 Apr 2014 08:57:43 +0200
Hello Abhishek,
Abhishek Anand
<abhishek.anand.iitg AT gmail.com>
writes:
> While waiting for a better solution, you could do the following hack in
> your .v file:
> (** #<a name="wf"></a># *)
> Inductive wf : process -> Prop :=
> Coqdoc's html output should then be what you wanted.
Thank you for the suggestion. Unfortunately this introduces a "doc" div,
which create an empty blue line. I could get rid of it through CSS, but
it would remove every "doc" div.
I guess I'll just post-process the generated html.
Thanks again,
Alan
- [Coq-Club] coqdoc: how do I make a keyword an identifier?, Alan Schmitt, 04/08/2014
- Re: [Coq-Club] coqdoc: how do I make a keyword an identifier?, Abhishek Anand, 04/08/2014
- Re: [Coq-Club] coqdoc: how do I make a keyword an identifier?, Alan Schmitt, 04/09/2014
