coq-club - Re: [Coq-Club] same type
  • From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] same type
  • Date: Sun, 13 Apr 2014 13:24:49 -0400
In an intensional type theory like Coq, even if you have types A and B that are propositionally equal (e.g. you have a proof of A=B),
a member of A is not a member of B unless A and B are definitonally equal ( A computes to B or vice versa).
This is necessary to keep typechecking decidable (definitial equality is decidable, but propositional equality is not).
So you need to do a "type-cast" with the propositional equality to do change the type of a term.
Recall that A=B is a notation for (eq A B), where eq is an inductively defined proposition.
Using the generated induction principle of eq (which is eq_rect), one can define such a "typecast" operator (see typeCast below).
After typecasting, the statement of your lemma typechecks (Coq 8.4pl2) :
Require Import List.
Definition transport {T:Type} {a b:T} {P:T -> Type} (eq:a=b) (pa: P a) : (P b):=
@eq_rect T a P pa b eq.
Definition typeCast {A B:Type}  (eq:A=B) (pa: A) : (B):=
@eq_rect Type A (fun X => X) pa B eq.
Record rec  : Type := mk_rec
  { t           : Type;
    stateset    : list t
Inductive t' : Type :=
  | A: t'.
Parameter P: t' -> Prop.
Lemma requality : forall {b T l},
b = mk_rec T l
-> t b = T.
Proof.
 intros  ? ? ? H.
rewrite H. auto.
Qed.
Example test:
  forall b (p : b = mk_rec t' (A::A::A::nil)),
   forall e, In e (@stateset b) -> P ( typeCast (requality p) e).
Proof.
On Sun, Apr 13, 2014 at 11:23 AM, Nuno Gaspar <nmpgaspar AT gmail.com> wrote:
Hello.
Consider the following:
  { t           : Type;
    stateset    : list t
  | A: t'.
Example test:
  forall b, b = mk_rec t' (A::A::A::nil) ->
   forall e, In e (@stateset b) -> P e.
Proof.
I cannot type the above lemma, as I get
Error: In environment
b : rec
e : t b
The term "e" has type "t b" while it is expected to have type "t'".
but t b, is actually equal to t'.. how can I make it work?
Cheers.
Bart: Look at me, I'm a grad student, I'm 30 years old and I made $600 dollars last year.
Marge: Bart! Don't make fun of grad students, they just made a terrible life choice.
