- To: coq-club AT inria.fr
- Cc: nmpgaspar AT gmail.com
- Subject: Re: [Coq-Club] same type
- Date: Sun, 13 Apr 2014 21:43:12 +0200
Le Sun, 13 Apr 2014 17:23:59 +0200,
Nuno Gaspar
<nmpgaspar AT gmail.com>
a écrit :
> Hello.
> Consider the following:
> Require Import List.
> Record rec : Type := mk_rec
> { t : Type;
> stateset : list t
> Inductive t' : Type :=
> | A: t'.
> Parameter P: t' -> Prop.
> Example test:
> forall b, b = mk_rec t' (A::A::A::nil) ->
> forall e, In e (@stateset b) -> P e.
> Proof.
> I cannot type the above lemma, as I get
> Error: In environment
> b : rec
> e : t b
> The term "e" has type "t b" while it is expected to have type "t'".
> but t b, is actually equal to t'.. how can I make it work?
> Cheers.
Something like this?
{ t : Type;
stateset : list t
| A: t'.
Definition ex_cast (a b : rec) : a = b -> t a -> t b :=
fun eq x => match eq in _=y return t y with eq_refl => x end.
Example test:
forall b (H : mk_rec t' (A::A::A::nil) = b),
forall e, In (ex_cast _ b H e) (@stateset b) -> P e.
Proof.
intros _ [].
simpl.
- [Coq-Club] same type, Nuno Gaspar, 04/13/2014
- Re: [Coq-Club] same type, Abhishek Anand, 04/13/2014
- Re: [Coq-Club] same type, AUGER Cédric, 04/13/2014
