- To: Karen Sargsyan <karsar AT ibms.sinica.edu.tw>
- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] bug or something else?
- Date: Tue, 22 Apr 2014 08:51:25 -0400
Perhaps the important missing piece of information here is that 8.3 and 8.4 are effectively different "major versions" of Coq, in terms of the extent of reorganization that is common when adding 0.1 or more to a Coq version number. It won't surprise me if you're just seeing the result of a big standard-library refactoring. Coq 8.3 was first released in 2010, and it's rather out of date today, regardless of the patch level.
On 04/22/2014 08:44 AM, Karen Sargsyan wrote:
If I do the following sequence on Ubuntu with Coq 8.3pl4 (ocaml 3.12.1):
Coq < Require Export ZArith.
Coq < Definition any: Z:= Z.div 2 3.
then result is: "Error: The reference Z.div was not found in the current environment"
On Mac OS X with 8.4pl2 OCaml 4.00.1 it defines "any".
So apparently there is some incompatibility between 8.3pl4 and 8.4pl2 in case of ZArith (something knows).
Is it so, or it's a bug in Ubuntu Coq package?
- [Coq-Club] bug or something else?, Karen Sargsyan, 04/22/2014
- Re: [Coq-Club] bug or something else?, Adam Chlipala, 04/22/2014
- Re: [Coq-Club] bug or something else?, Karen Sargsyan, 04/22/2014
