coq-club - Re: [Coq-Club] Module type question
  • From: Pierre Courtieu <pierre.courtieu AT gmail.com>
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Module type question
  • Date: Mon, 28 Apr 2014 18:00:03 +0200
Hello, it seems that this is not possible. I am not sure why.
This is the closest solution I could find: Notice that Include can
avoid duplications in some cases.
Hope this helps,
Pierre
Module Type m.
Variable T :Set.
End m.
Module Type mt.
Include m.
Parameter foo : T -> T.
End mt.
Module Type mtt <: mt.
Include m.
Definition foo := (fun x:T => x).
End mtt.
------------- Another solution with typed functor: -----------
Module Type m.
Variable T :Set.
End m.
Module Type mt(M:m).
Include M.
End mt.
Module Type mtt(M:m)<: mt(M) with Definition foo:= (fun x:M.T => x).
Include M.
Definition foo := (fun x:M.T => x).
End mtt.
2014-04-21 21:53 GMT+02:00 Eddy Westbrook
<westbrook AT kestrel.edu>:
> All,
> I asked this a while ago, but got no answer, so I am seeing if maybe I can
> try again.
> The question: how can I write a “with” clause in a module type that refers
> to a name already defined in the existing module type? That is, I want to
> write something like
> Module Type mt’ := mt with Definition foo := fun (x:T) => x.
> where mt has the following definition:
> Module Type mt.
> Parameter T : Set.
> End mt.
> Or maybe there is some alternative way to update a name in a module type,
> to give it a definition? Any suggestions?
> Thanks very much,
> -Eddy
