- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] external proof of termination
- Date: Mon, 28 Apr 2014 11:06:34 -0700
Arnaud,
Wait a second, this cannot be quite right. I have been looking at Werner’s “Sets in Types, Types in Sets” paper, where he proves that ZF with inaccessible cardinals is equi-consistent with Coq plus a few axioms, including propositional excluded middle (pEM) and the type-theoretic description axiom (TTDA). I have shown that pEM and TTDA imply the existence of a strong sum axiom that you describe. Specifically, I have shown (in Coq) that
pEM -> TTDA_(i+1) -> (exists _:SS_i , True)
where TTDA_i is TTDA at level i and SS_i is strong sums at level i. (I have attached the Coq file below, so you can double-check that I have gotten everything right.) In fact, I have shown the converse as well, i.e., that the consistency of strong sums is equivalent to that of TTDA at one level higher: it turns out that both of these are equivalent to excluded middle for Type at the same level as the strong sums.
Of course, this seems to contradict part of Coquand’s paper, so I looked back over it again and I think maybe I found an issue in his definition of A_0 for strong sums. Specifically, he defines
A_0 = Sigma (C : Prop) (C -> C -> Prop)
which I do not think satisfies his definition of a universal system of notations, at least not in the Coq type system, because C here has to be a Prop, not an arbitrary type. And, of course, if we switch to
A_0 = Sigma (C : Type) (C -> C -> Prop)
for some given type universe i, then his WF well-roundedness relation moves up to the next universe, and so cannot be captured inside of A_0. Does this seem right to you, or am I missing something?
Thanks,
-Eddy
strong_sums.v
Description: Binary data
On Apr 28, 2014, at 1:03 AM, Arnaud Spiwack <aspiwack AT lix.polytechnique.fr> wrote:
For the records, assuming I am parsing this correctly as [ (exists x, P x) -> { x | P x } ]. This is known to be inconsistent in general (you can use it to encode system U). It is a very strong property (because of impredicativity). See, Coquand's An Analysis of Girard's Paradox (LICS 1986).Coq is believed to be consistent with the axiom [exists x, P x -> { x | P x }].
/Arnaud
- [Coq-Club] external proof of termination, Kirill Taran, 04/25/2014
- Re: [Coq-Club] external proof of termination, Adam Chlipala, 04/25/2014
- Re: [Coq-Club] external proof of termination, Jason Gross, 04/25/2014
- Re: [Coq-Club] external proof of termination, Arnaud Spiwack, 04/28/2014
- Re: [Coq-Club] external proof of termination, Eddy Westbrook, 04/28/2014
- Re: [Coq-Club] external proof of termination, Arnaud Spiwack, 04/30/2014
- Re: [Coq-Club] external proof of termination, Eddy Westbrook, 04/25/2014
- Re: [Coq-Club] external proof of termination, Kirill Taran, 04/25/2014
- Re: [Coq-Club] external proof of termination, gallais, 04/28/2014
- Re: [Coq-Club] external proof of termination, Guillaume Melquiond, 04/25/2014
