- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: [Coq-Club] Type class resolution issue
- Date: Tue, 13 May 2014 14:05:43 +0000
- Accept-language: en-GB, en-US
- Authentication-results: spf=pass (sender IP is 131.107.125.37) smtp.mailfrom=akenn AT microsoft.com;
Hello
I'm puzzled by a failure of type class resolution in my Coq code; unless I am
completely explicit and supply the full instance information the code does
not type check, even though it seems to me that it is unambiguous. I have
boiled it down to a smallish fragment, shown below. Note that the "StateIs"
class uses T to determine both a type (the type associated with the
"variable" type T) and an "variable-is" predicate.
Any help much appreciated!
Cheers
Andrew.
Inductive BoolVar := IsRaining | IsSunny.
Inductive NatVar := Year | Month | Day.
Inductive State :=
| mkState (nats: NatVar -> nat) (bools: BoolVar -> bool).
Definition eqState s1 s2 :=
match s1, s2 with
| mkState n1 b1, mkState n2 b2 => forall v, n1 v = n2 v /\ forall v, b1 v =
b2 v
end.
Inductive SProp :=
| mkSProp (st: State -> Prop).
Class StateIs T := {
valueType : Type;
stateIs : T -> valueType -> SProp
Notation "x ~ y" := (stateIs x y) (at level 10).
Instance NatStateIs : StateIs NatVar := {
valueType := nat;
stateIs x v := mkSProp (fun s => match s with mkState n b => n x = v end)
Instance BoolStateIs : StateIs BoolVar := {
valueType := bool;
stateIs x v := mkSProp (fun s => match s with mkState n b => b x = v end)
Class LogicOps F := {
land: F -> F -> F
Notation "x //\\ y" := (land x y) (at level 40).
Instance SPropLogicOps : LogicOps SProp := { land := fun P Q =>
match P, Q with mkSProp SP, mkSProp SQ => mkSProp (fun s => SP s /\ SQ s)
end }.
Instance PropLogicOps : LogicOps Prop := { land := and }.
(* This doesn't resolve, if PropLogicOps is defined later than SPropLogicOps
Definition BAD (v: NatVar) (n: nat) : SProp :=
v ~ n //\\ Year ~ 2014.
- [Coq-Club] Type class resolution issue, Andrew Kennedy, 05/13/2014
- Re: [Coq-Club] Type class resolution issue, Jason Gross, 05/13/2014
