- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Type class resolution issue
- Date: Tue, 13 May 2014 16:53:21 +0200
I don't have an explanation, but here's a smaller example:
Axiom SProp : Set.
Axiom sp : SProp.
(* If we hardcode valueType := nat, it goes through *)
Class StateIs := {
valueType : Type;
stateIs : valueType -> SProp
Instance NatStateIs : StateIs := {
valueType := nat;
stateIs := fun _ => sp
Class LogicOps F := { land: F -> F }.
Instance : LogicOps SProp. Admitted.
Instance : LogicOps Prop. Admitted.
Set Printing All.
Parameter (n : nat).
(* If this is a [Definition], the resolution goes through fine. *)
Notation vn := (@stateIs _ n).
(* This doesn't resolve, if PropLogicOps is defined later than SPropLogicOps *)
Definition BAD : SProp :=
@land _ _ vn.
Perhaps there's a bug in typeclass resolution when the instance we're picking out is determined by a field of the class? Maybe this should be reported on the bug tracker?
-Jason
On Tue, May 13, 2014 at 4:05 PM, Andrew Kennedy <akenn AT microsoft.com> wrote:
Hello
I'm puzzled by a failure of type class resolution in my Coq code; unless I am completely explicit and supply the full instance information the code does not type check, even though it seems to me that it is unambiguous. I have boiled it down to a smallish fragment, shown below. Note that the "StateIs" class uses T to determine both a type (the type associated with the "variable" type T) and an "variable-is" predicate.
Any help much appreciated!
Cheers
Andrew.
Inductive BoolVar := IsRaining | IsSunny.
Inductive NatVar := Year | Month | Day.
Inductive State :=
| mkState (nats: NatVar -> nat) (bools: BoolVar -> bool).
Definition eqState s1 s2 :=
match s1, s2 with
| mkState n1 b1, mkState n2 b2 => forall v, n1 v = n2 v /\ forall v, b1 v = b2 v
end.
Inductive SProp :=
| mkSProp (st: State -> Prop).
Class StateIs T := {
valueType : Type;
stateIs : T -> valueType -> SProp
Notation "x ~ y" := (stateIs x y) (at level 10).
Instance NatStateIs : StateIs NatVar := {
valueType := nat;
stateIs x v := mkSProp (fun s => match s with mkState n b => n x = v end)
Instance BoolStateIs : StateIs BoolVar := {
valueType := bool;
stateIs x v := mkSProp (fun s => match s with mkState n b => b x = v end)
land: F -> F -> F
Notation "x //\\ y" := (land x y) (at level 40).
Instance SPropLogicOps : LogicOps SProp := { land := fun P Q =>
match P, Q with mkSProp SP, mkSProp SQ => mkSProp (fun s => SP s /\ SQ s) end }.
Instance PropLogicOps : LogicOps Prop := { land := and }.
Definition BAD (v: NatVar) (n: nat) : SProp :=
v ~ n //\\ Year ~ 2014.
- [Coq-Club] Type class resolution issue, Andrew Kennedy, 05/13/2014
- Re: [Coq-Club] Type class resolution issue, Jason Gross, 05/13/2014
