- To: coq-club <coq-club AT inria.fr>
- Subject: [Coq-Club] Using typeclasses to make tactics recurse under binders
- Date: Fri, 23 May 2014 18:57:38 -0400
Hi,
I realized today that it is possible to make tactics that recurse under binders using typeclasses; I had previously thought that this was possible only in Coq trunk using tactics in terms. If anyone else is interested in making their tactics recurse under binders on a tactic-by-tactic basis, here is some code demo-ing the trick:
Class ret_and_left {T} (arg : T) {R} := make_recur_ret_and_left : R.
Ltac ret_and_left_helper f :=
let T := type of f in
lazymatch eval hnf in T with
| ?a /\ ?b => exact (proj1 f)
| ?T' -> _
=> exact (fun x' : T' => _ : ret_and_left (f x'))
end.
Hint Extern 0 (@ret_and_left _ ?f _) => ret_and_left_helper f : typeclass_instances.
Arguments ret_and_left / .
Goal forall A B : Prop, (A -> A -> A /\ B) -> True.
intros A B H.
pose (_ : ret_and_left H) as H'; simpl in H'.
(* fun x' x'0 : A => proj1 (H x' x'0) : A -> A -> A *)
The idea is that, wherever you want to call the tactic recursively, you instead ask for a typeclass instance of the related class, and you pass the arguments to the class instead.
-Jason
- [Coq-Club] Using typeclasses to make tactics recurse under binders, Jason Gross, 05/24/2014
