coq-club - Re: [Coq-Club] Installing on Linux
  • From: Kevin Sullivan <sullivan.kevinj AT gmail.com>
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Installing on Linux
  • Date: Thu, 22 May 2014 13:56:53 -0400
PLEASE IGNORE PREVIOUS MESSAGE. Wrong VM was selected. Sorry for the noise. --Kevin
On Thu, May 22, 2014 at 1:52 PM, Kevin Sullivan <sullivan.kevinj AT gmail.com> wrote:
I could spend all day doing systems hacking, but please forgive me if I just ask here first. I'm trying this shortcut not only for myself, but because I'm sure that this situation will frustrate my students if/when they try to do the same thing.
To install coq and coqide on linux, I followed the instructions here, http://coq.inria.fr/cocorico/Installation%20of%20Coq%20on%20Linux, namely
sudo apt-get install coq coqide
The machine on which I'm installing is an almost fresh Ubuntu 14.04 LTS VM. I have installed OCaml, following the directions on the OCaml site: first install package manager, then install a bunch of additional programs and resources. Here's what I get when I now try to install Coq:
"Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation:
The following packages have unmet dependencies:
 coq : Depends: libcoq-ocaml-k3dy8
       Depends: ocaml-base-nox-3.12.1
 coqide : Depends: libcoq-ocaml-k3dy8
          Depends: liblablgtk2-ocaml-yfv67
Best,
Kevin
