- From: Robbert Krebbers <mailinglists AT robbertkrebbers.nl>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] implicit arguments to parameters
- Date: Sun, 01 Jun 2014 17:53:40 +0200
Not that I am aware of, if you do
Definition D1 : Type := forall {T : Type} (x : T), Type.
Coq tells "Warning: Ignoring implicit status of product binder T and following binders". You could create a feature request.
An alternative is to create an auxiliary definition or notation, like
Definition foo (A : D1) {T} (x : T) := A T x.
or
Notation foo A x := (A _ x).
And then write
Definition DD1 (A : D1) := forall x : bool, foo A x.
Depending on the use case, this may actually be worse...
On 06/01/2014 03:12 PM, Vladimir Voevodsky wrote:
Hi,
I have a type of the form (I am using a simplified example):
Definition D1 : Type := forall ( T : Type ) ( x : T ) , Type .
I now have other definitions which use D1 as a type of a parameter:
Definition DD1 ( A : D1 ) := ....
Definition DD2 ( A : D1 ) := ....
etc.
I am going to use A : D1, mostly, fully applied i.e. in the form A T x . I
do not want to write T in A T x all the time since it can be easily inferred
from x . Is there a way to write something like:
Definition D1 : Type := forall { T : Type } ( x : T ) , Type .
and then to write A x ?
Vladimir.
- [Coq-Club] implicit arguments to parameters, Vladimir Voevodsky, 06/01/2014
- Re: [Coq-Club] implicit arguments to parameters, sdk, 06/01/2014
- Re: [Coq-Club] implicit arguments to parameters, Robbert Krebbers, 06/01/2014
- Re: [Coq-Club] implicit arguments to parameters, Jason Gross, 06/02/2014
- Re: [Coq-Club] implicit arguments to parameters, Arnaud Spiwack, 06/03/2014
