coq-club - Re: [Coq-Club] implicit arguments to parameters
  • To: coq-club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] implicit arguments to parameters
  • Date: Sun, 1 Jun 2014 23:40:16 +0100
I have submitted a bug report which, if fixed, would let you do this by making [D1] an alias/notation.
-Jason
On Jun 1, 2014 4:54 PM, "Robbert Krebbers" <mailinglists AT robbertkrebbers.nl> wrote:
Not that I am aware of, if you do
  Definition D1 : Type := forall {T : Type} (x : T), Type.
Coq tells "Warning: Ignoring implicit status of product binder T and following binders". You could create a feature request.
An alternative is to create an auxiliary definition or notation, like
  Definition foo (A : D1) {T} (x : T) := A T x.
or
  Notation foo A x := (A _ x).
And then write
  Definition DD1 (A : D1) := forall x : bool, foo A x.
Depending on the use case, this may actually be worse...
On 06/01/2014 03:12 PM, Vladimir Voevodsky wrote:
Hi,
I have a type of the form (I am using a simplified example):
Definition D1 : Type := forall ( T : Type ) ( x : T ) , Type .
I now have other definitions which use D1 as a type of a parameter:
Definition DD1 ( A : D1 ) := ....
Definition DD2 ( A : D1 ) := ....
etc.
I am going to use A : D1, mostly, fully applied i.e. in the form  A T x . I do not want to write T in A T x all the time since it can be easily inferred from x . Is there a way to write something like:
Definition D1 : Type := forall { T : Type } ( x : T ) , Type .
and then to write A x ?
Vladimir.
