- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Rewrite question
- Date: Mon, 2 Jun 2014 12:43:12 +0200
As hinted, did you try to change the display options.
I do not know if it is the case here, but implicit parameters can be tricky from time to time.
For instance, imagine you have:
A predicate "foo" which first argument is implicit,
"@foo (f x) y = z" in your hypothesis and
"P (@foo w y) -> P z" as your goal, and furthermore, "f x" reduces to w.
Then you cannot rewrite your hypothesis in your goal as they are not syntactically equal.
If you have the default displaying options, still, it will look like:
"foo y = z" in your hypothesis and
"P (foo y) -> P z" as your goal
which might be a situation similar to the one you had.
Often a "simpl in *." before the rewrite can reduce terms so that they become syntactically equal.
2014-06-01 19:05 GMT+02:00 Marcus Ramos <marcus.ramos AT univasf.edu.br>:
Replace worked, thanks. However, I still don´t understand why rewrite <- did not work in this case.Best Regards,Marcus.2014-05-31 16:23 GMT+02:00 plastyx <plastyx AT free.fr>:Let's tryreplace (s' ++ map (g_clo_sf_lift g) s'') with (s2 ++ inl (Start_clo g) :: s3).Sometime things no longer remains the same when "display" options are changed ;)----- Original Message -----From: Marcus RamosSent: Friday, May 30, 2014 8:19 PMSubject: [Coq-Club] Rewrite questionHi,I must be missing something quite obvious, but right now I can´t see why rewrite doesn´t work in the current subgoal (see below). As I can see, the right hand side of H3 matches exactly a subterm in the goal. Any help will be appreciated.CONTEXT+SUBGOALS:================2 subgoalg : cfgs2 : sf (g_clo g)s3 : sf (g_clo g)s' : sf (g_clo g)s'' : sf gH1 : derives (g_clo g) [inl (Start_clo g)] s'H2 : derives g [inl (start_symbol g)] s''H : derives (g_clo g) [inl (Start_clo g)] (s2 ++ inl (Start_clo g) :: s3)H3 : s2 ++ inl (Start_clo g) :: s3 = s' ++ map (g_clo_sf_lift g) s''H0 : g_clo_rules g (Start_clo g)[inl (Start_clo g); inl (Transf_clo g (start_symbol g))]______________________________________(1/2)In (inl (Start_clo g)) (s' ++ map (g_clo_sf_lift g) s'')______________________________________(2/2)derives (g_clo g) [inl (Start_clo g)] [] \/(exists (s'0 : sf (g_clo g)) (s''0 : sf g),derives (g_clo g) [inl (Start_clo g)] s'0 /\derives g [inl (start_symbol g)] s''0 /\s2 ++ inl (Start_clo g) :: inl (Transf_clo g (start_symbol g)) :: s3 =s'0 ++ map (g_clo_sf_lift g) s''0)SCRIPT:======...rewrite <- H3....SYSTEM MESSAGE:==============Error:Found no subterm matching "s' ++ map (g_clo_sf_lift g) s''" in the current goal.Thanks in advance,Marcus.
.../Sedrikov\...
- Re: [Coq-Club] Rewrite question, Marcus Ramos, 06/01/2014
- Re: [Coq-Club] Rewrite question, Cedric Auger, 06/02/2014
- Re: [Coq-Club] Rewrite question, Marcus Ramos, 06/03/2014
- Re: [Coq-Club] Rewrite question, Cedric Auger, 06/04/2014
- Re: [Coq-Club] Rewrite question, Marcus Ramos, 06/04/2014
