coq-club - Re: [Coq-Club] coercions and universes
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] coercions and universes
  • Date: Mon, 02 Jun 2014 11:44:53 +0200
Indeed, [Identity Coercion foo : UU >-> Sortclass.] works.
Thanks a lot,
Benedikt
On 06/02/2014 11:14 AM, Jason Gross wrote:
The coercion mechanism does not do delta/unfolding. It sees ": C", looks
for a coercion to "Sortclass", finds none, and errors. It does not look
for the hnf of every coercion it has, seeing if one of them is [Type]. You
may be able to get around this by declaring an [Identity Coercion] between
UU and Sortclass, or else declaring an identity function as a coercion from
UU to Sortclass. Alternatively, you can do [c : (C : UU)] instead of [c :
C], or you can make some hacky notation like saying that [x `: y] means [x
: (y : UU)] or something, and use that.
-Jason
On Jun 2, 2014 9:45 AM, "Benedikt Ahrens"
<benedikt.ahrens AT irit.fr>
wrote:
Hello,
of the two pieces of code below, the first one is accepted whereas the
second one does not typecheck; the line "Check..." fails (in Coq8.4pl3).
Could someone explain why? Is this a necessary restriction of the coercion
mechanism?
Thanks a lot in advance.
Benedikt
=== 1 ===
Definition UU := Type.
Definition PointedUU := sigT (fun A : UU => A).
Definition carrier (C : PointedUU) : Type := @projT1 _ _ C.
Coercion carrier : PointedUU >-> Sortclass.
Check (fun C : PointedUU => fun c : C => c).
=== 2 ===
Definition carrier (C : PointedUU) := @projT1 _ _ C.
Coercion carrier : PointedUU >-> UU.
Check (fun C : PointedUU => fun c : C => c). (* fails *)
