- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Rewrite doesn't work. What did I do wrong?
- Date: Thu, 5 Jun 2014 01:41:47 +0200
If you enter
Set Printing All.
Show.
Then you will see that (v1 (fin_zero n)) in your goal looks different
than "the same" term in H0 - some coercions between sig and sigT
slipped in. You have two choices:
1) reduce the coercions by proving and applying a quick lemma:
Lemma sigsigT : forall A (P:A->Prop) (s : sig P), sig_of_sigT
(sigT_of_sig s) = s.
destruct s; trivial.
Qed.
now:
rewrite sigsigT in H0.
and your
rewrite H0.
works!
2) replace projT1 with proj1_sig in your definition aux3 and you will
have no coercions and rewrite H0 will just work!
Bests,
Jacek
2014-06-04 22:24 GMT+02:00 Ilmārs Cīrulis
<ilmars.cirulis AT gmail.com>:
> Definition fin limit := {n | n <= limit}.
> Definition vect A limit := fin limit -> A.
> Definition fin_zero limit: fin limit.
> exists O; induction limit; auto.
> Defined.
> Definition aux3 {n} (v1 v2: vect bool n):
> (forall i, projT1 i <= O -> v1 i = false \/ v2 i = false) -> andb (v1
> (fin_zero n)) (v2 (fin_zero n)) = false.
> intros. destruct (H (fin_zero n) (le_n O)).
> rewrite H0.
> (* Error: Found no subterm matching "v1 (fin_zero n)" in the current goal.
> (* Goal: (v1 (fin_zero n) && v2 (fin_zero n))%bool = false *)
- [Coq-Club] Rewrite doesn't work. What did I do wrong?, Ilmārs Cīrulis, 06/04/2014
- Re: [Coq-Club] Rewrite doesn't work. What did I do wrong?, Jacek Chrząszcz, 06/05/2014
- Re: [Coq-Club] Rewrite doesn't work. What did I do wrong?, Ilmārs Cīrulis, 06/05/2014
- Re: [Coq-Club] Rewrite doesn't work. What did I do wrong?, Cedric Auger, 06/05/2014
- Re: [Coq-Club] Rewrite doesn't work. What did I do wrong?, Jason Gross, 06/05/2014
