coq-club - Re: [Coq-Club] Rewrite doesn't work. What did I do wrong?
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Rewrite doesn't work. What did I do wrong?
  • Date: Thu, 5 Jun 2014 02:59:40 +0300
I found such solution just now:
Definition aux3 {n} (v1 v2: vect bool n):
  (forall (i: fin n), projT1 i <= O -> v1 i = false \/ v2 i = false) -> andb (v1 (fin_zero n)) (v2 (fin_zero n)) = false.
 intros. destruct (H (fin_zero n) (le_n O)). rewrite H0.
(* Now it works! *)
I added type to variable "i". Now it's fin n or { n0: nat | n0 <= n}, and that's different from {n0 : nat & n0 <= n}. (sig and sigT)
Thank you,
Ilmars
On Thu, Jun 5, 2014 at 2:41 AM, Jacek Chrząszcz <chrzaszcz AT mimuw.edu.pl> wrote:
If you enter
Set Printing All.
Show.
Then you will see that (v1 (fin_zero n)) in your goal looks different
than "the same" term in H0 - some coercions between sig and sigT
slipped in. You have two choices:
1) reduce the coercions by proving and applying a quick lemma:
Lemma sigsigT : forall A (P:A->Prop) (s : sig P), sig_of_sigT
(sigT_of_sig s) = s.
  destruct s; trivial.
Qed.
now:
rewrite sigsigT in H0.
and your
rewrite H0.
works!
2) replace projT1 with proj1_sig in your definition aux3 and you will
have no coercions and rewrite H0 will just work!
Bests,
Jacek
2014-06-04 22:24 GMT+02:00 Ilmārs Cīrulis <ilmars.cirulis AT gmail.com>:
> Definition fin limit := {n | n <= limit}.
> Definition vect A limit := fin limit -> A.
> Definition fin_zero limit: fin limit.
>  exists O; induction limit; auto.
> Defined.
>   (forall i, projT1 i <= O -> v1 i = false \/ v2 i = false) -> andb (v1
>  rewrite H0.
> (* Error: Found no subterm matching "v1 (fin_zero n)" in the current goal.
> (* Goal: (v1 (fin_zero n) && v2 (fin_zero n))%bool = false *)
