coq-club - Re: [Coq-Club] aren't (x = n -> y = n) and (x = y) the same thing?
  • To: Bruno Woltzenlogel Paleo <bruno.wp AT gmail.com>
  • Cc: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] aren't (x = n -> y = n) and (x = y) the same thing?
  • Date: Wed, 11 Jun 2014 10:46:55 +0200
Something very simple:
Fixpoint my_plus (x y : nat) : nat :=
  match x with
  | O => y
  | S x => my_plus x (S y)
  end.
Now, if you want to prove "∀ x, my_plus x O = x", when performing induction on x, you will be in the following situation:
"IHx : my_plus x O = x ⊢ my_plus x (S O) = S x", and you will get stuck.
Thus you will need for instance to first "intros x; change (my_plus x O = O + x).". Then you "generalize O.", and you can "induction x.".
There, your situation will be more general, and you can prove it:
"IHx : ∀ y, my_plus x y = y+x ⊢ my_plus x (S y) = y+S x", which can then be turned into "S y+x = y+S x" by rewriting IHx.
I really did not mean more.
2014-06-11 7:42 GMT+02:00 Bruno Woltzenlogel Paleo <bruno.wp AT gmail.com>:
Hi Cedric,
> When you perform some induction, you sometimes need to generalize your goal.
This is interesting. Could you state a simple (if possible, "simplest") example goal where this happens?
Thanks!
Best regards,
Bruno
.../Sedrikov\...
