coq-club - Re: [Coq-Club] Why does rewrite fail here?
  • From: Matthieu Sozeau <matthieu.sozeau AT gmail.com>
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Why does rewrite fail here?
  • Date: Wed, 11 Jun 2014 11:35:49 +0200
Hi,
setoid_rewrite doesn’t try to match with “sub applications” of f x’ x’,
hence it
doesn’t find a match for the lhs of the lemma. Without a condition like
ssreflect’s
“head symbols must match syntactically” this would result in a lot of
time-consuming
failed unifications I suppose. One way to work around this limitation would
be to
eta-expand your hypothesis.
Best,
— Matthieu
On 11 juin 2014, at 08:25, Arnaud Spiwack
<aspiwack AT lix.polytechnique.fr>
wrote:
> In its current version, rewrite … at uses setoid rewrite even if the
> relation is equality. I have no idea why setoid rewrite would fail on this
> instance though.
> On 10 June 2014 19:32, Maxime Dénès
> <mail AT maximedenes.fr>
> wrote:
> Three side notes:
> - Removing the Require Import Setoid wil make Coq ask for it, which seems
> strange because the relation is equality.
> - ssreflect's rewrite works fine (without using setoids).
> - Without the selection of occurrences, rewrite succeeds in the two places,
> with or without the Require.
> So it's probably a bug.
> Maxime.
> On 06/10/2014 01:10 PM, Gert Smolka wrote:
> Why does rewrite fail in the following script? Is this a feature or a bug?
> Thanks for a hint, Gert
> Require Import Setoid.
> Lemma rewrite_fails X Y (f : X -> X -> Y) (g : Y -> Y) x' :
> f x' = (fun x : X => g (f x x)) -> g (f x' x') = f x' x'.
> Proof.
> intros E. rewrite E at 2.
> (* Error: Tactic failure:Nothing to rewrite. *)
