coq-club - Re: [Coq-Club] Slow iterated sigmas
  • To: coq-club <coq-club AT inria.fr>
  • Cc: "Prof. Vladimir Voevodsky" <vladimir AT ias.edu>, Erik Palmgren <palmgren AT math.su.se>
  • Subject: Re: [Coq-Club] Slow iterated sigmas
  • Date: Mon, 16 Jun 2014 09:24:35 +0100
Your proof would become:
refine ( constr _ _ ).
{ abstract (apply a1; exact b1). }
{ apply a2. exact b2. }
Defined.
See for example, my formalization of the Grothendieck construction of a pseudofunctor to Cat.
On Mon, Jun 16, 2014 at 9:09 AM, Vladimir Voevodsky <vladimir AT ias.edu> wrote:
This sounds usefu but I did not understand how to use it in practice.
Suppose my proof is
{ apply a1. exact b1. }
Defined.
How do I "abstract" the first argument of constr?
V.
On Jun 15, 2014, at 11:00 PM, AUGER Cédric <sedrikov AT gmail.com> wrote:
> Le Sun, 15 Jun 2014 20:01:10 +0000,
> Erik Palmgren <palmgren AT math.su.se> a écrit :
>> Many thanks to Matthieu, Bas and Vladimir, for the hints how to
>> improve proof performance. The suggested separation of data and
>> proofs (for setoids and categories) seems to have speeded up the
>> first part of the proof, but slowed down the final part, probably
>> since further levels of records/existentials were introduced.  In
>> total a slightly worse runtime: from 34 min 40 sec to 34 min 50 sec
>> on the Mac Book Air I am using. I guess the main problem is what
>> Matthieu describes below. In general I would like to end all proofs
>> with "Defined", since I may need the constructions of the proofs
>> later.
> The "abstract" tactic can be quite helpful for this kind of things.
> For instance, you can do something like:
> Definition foo : bar.
> Proof.
> <regular tactics for parts you want transparent>
> abstract (<opaque proof part>).
> Defined.
> This is especially useful in combination with the refine tactic.
> Definition foo : {x : bar | P x}.
> refine (existT P (f x) _).
> abstract (my_tactic).
> Defined.
>> Best regards
>> Erik
>> ________________________________
>> Från: matthieu.sozeau AT gmail.com [matthieu.sozeau AT gmail.com] för
>> Matthieu Sozeau [matthieu.sozeau AT inria.fr] Skickat: den 15 juni 2014
>> 12:12 Till: coq-club AT inria.fr
>> Ämne: [Coq-Club] Slow iterated sigmas
>> Hi Erik,
>>  Apart from Vladimir's answer about separating "data" and proofs,
>> there is a known problem of representation when using projections of
>> sigma types and parametrized records that you might be experiencing.
>> Each projection takes all the parameters as arguments, and in
>> nested/iterated cases this can lead to a blowup in proof-term size
>> and type checking time. You can check that this happens using Set
>> Printing All, the actual proof term should be much much larger than
>> what you see if implicit arguments are hidden. The next version (and
>> current trunk) will have support for a more economical representation
>> that solves that problem. -- Matthieu
>> On Saturday, June 14, 2014, Erik Palmgren
>> <palmgren AT math.su.se<UrlBlockedError.aspx>> wrote:
>> Here is a remark I made some time ago. I am getting, what I think,
>> absurdly slow response from Coq when checking proofs involving many
>> iterated sigmas or records. There was some improvement when upgrading
>> from 8.3 to 8.4, and rearranging some sigma-constructions, but it is
>> still too hard for the quite modest complexity I am considering.
>> I am using an alternative development of setoids, since I want to
>> the truth-values of equality to be in Set rather than in the
>> Coq-standard Prop. The goal of the development is to construct a
>> category of setoids closed under the various categorical
>> constructions as pullbacks, pushouts and internal products etc. I see
>> no principal difficulties in this, but the implementation in Coq has
>> turned to be quite frustrating, because of the slowness of checking
>> proofs. So far just proving closure for pullbacks, has required
>> machine times of up to an hour.
>> Does anyone have an idea for how to improve performance?
>> The URL
>> http://people.su.se/~epalm/coq/czf_and_setoids/
>> contains
>> CategoricalUniverse-test12.v<http://people.su.se/~epalm/coq/czf_and_setoids/CategoricalUniverse-test12.v>
>> which is the actual development (it may require recompilation).
>> Best regards
>> Erik Palmgren
