- To: AUGER Cédric <sedrikov AT gmail.com>, "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: SV: [Coq-Club] Slow iterated sigmas
- Date: Sat, 21 Jun 2014 20:49:11 +0000
- Accept-language: sv-SE, en-US
Thanks for this advice. I will probably use it in the next extension. Anyway
I managed to improve the proof by introducing many explicit subsidiary
lemmas, so the checking time went down from 34 minutes to under 3 minutes!
Quite reasonable performance. It seems that the exponential behavior of
iterated sigmas could be beaten this way, in this case anyway.
Best regards
Erik
________________________________________
Från: AUGER Cédric
[sedrikov AT gmail.com]
Skickat: den 15 juni 2014 23:00
Till:
Kopia: Erik Palmgren
Ämne: Re: [Coq-Club] Slow iterated sigmas
Le Sun, 15 Jun 2014 20:01:10 +0000,
Erik Palmgren
<palmgren AT math.su.se>
a écrit :
> Many thanks to Matthieu, Bas and Vladimir, for the hints how to
> improve proof performance. The suggested separation of data and
> proofs (for setoids and categories) seems to have speeded up the
> first part of the proof, but slowed down the final part, probably
> since further levels of records/existentials were introduced. In
> total a slightly worse runtime: from 34 min 40 sec to 34 min 50 sec
> on the Mac Book Air I am using. I guess the main problem is what
> Matthieu describes below. In general I would like to end all proofs
> with "Defined", since I may need the constructions of the proofs
> later.
The "abstract" tactic can be quite helpful for this kind of things.
For instance, you can do something like:
Definition foo : bar.
Proof.
<regular tactics for parts you want transparent>
abstract (<opaque proof part>).
Defined.
This is especially useful in combination with the refine tactic.
Definition foo : {x : bar | P x}.
refine (existT P (f x) _).
abstract (my_tactic).
Defined.
> Best regards
> Erik
> Från:
> matthieu.sozeau AT gmail.com
> [matthieu.sozeau AT gmail.com]
> för
> Matthieu Sozeau
> [matthieu.sozeau AT inria.fr]
> 12:12 Till:
> Ämne: [Coq-Club] Slow iterated sigmas
> Hi Erik,
> Apart from Vladimir's answer about separating "data" and proofs,
> there is a known problem of representation when using projections of
> sigma types and parametrized records that you might be experiencing.
> Each projection takes all the parameters as arguments, and in
> nested/iterated cases this can lead to a blowup in proof-term size
> and type checking time. You can check that this happens using Set
> Printing All, the actual proof term should be much much larger than
> what you see if implicit arguments are hidden. The next version (and
> current trunk) will have support for a more economical representation
> that solves that problem. -- Matthieu
> On Saturday, June 14, 2014, Erik Palmgren
> <palmgren AT math.su.se<UrlBlockedError.aspx>>
> wrote:
> Here is a remark I made some time ago. I am getting, what I think,
> absurdly slow response from Coq when checking proofs involving many
> iterated sigmas or records. There was some improvement when upgrading
> from 8.3 to 8.4, and rearranging some sigma-constructions, but it is
> still too hard for the quite modest complexity I am considering.
> I am using an alternative development of setoids, since I want to
> the truth-values of equality to be in Set rather than in the
> Coq-standard Prop. The goal of the development is to construct a
> category of setoids closed under the various categorical
> constructions as pullbacks, pushouts and internal products etc. I see
> no principal difficulties in this, but the implementation in Coq has
> turned to be quite frustrating, because of the slowness of checking
> proofs. So far just proving closure for pullbacks, has required
> machine times of up to an hour.
> Does anyone have an idea for how to improve performance?
> The URL
> http://people.su.se/~epalm/coq/czf_and_setoids/
> contains
> CategoricalUniverse-test12.v<http://people.su.se/~epalm/coq/czf_and_setoids/CategoricalUniverse-test12.v>
> which is the actual development (it may require recompilation).
> Best regards
> Erik Palmgren
- [Coq-Club] Slow iterated sigmas, Erik Palmgren, 06/14/2014
- Re: [Coq-Club] Slow iterated sigmas, Vladimir Voevodsky, 06/14/2014
- [Coq-Club] Slow iterated sigmas, Matthieu Sozeau, 06/15/2014
- SV: [Coq-Club] Slow iterated sigmas, Erik Palmgren, 06/15/2014
- Re: [Coq-Club] Slow iterated sigmas, AUGER Cédric, 06/15/2014
- Re: [Coq-Club] Slow iterated sigmas, Jason Gross, 06/16/2014
- Re: [Coq-Club] Slow iterated sigmas, Vladimir Voevodsky, 06/16/2014
- Re: [Coq-Club] Slow iterated sigmas, Cedric Auger, 06/16/2014
- SV: [Coq-Club] Slow iterated sigmas, Erik Palmgren, 06/21/2014
