- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] [coqdev] Tactic for detecting that there is a goal left?
- Date: Wed, 18 Jun 2014 11:40:23 -0400
On 06/18/2014 08:10 AM, Arnaud Spiwack wrote:
Let me try to give a more precise account of the situation in trunk. Thisis that t;[t1|…|tn] is *not* of the form t;t'. It is easily witnessed in
is a long mail, but please read it if you are interested in this thread,
because I value (need?) your input.
A tactic can be seen as a function goal list -> goal list which updates a
partial proof as a side-effect. Natively, a tactic manipulates a list of
goal. A tactic could just reorder the goals, for instance (though I haven't
written a syntax for that), or could count the goals. There is currently
one tactic, in trunk, which strongly exploits this ability:
shelve_unifiable (it hides all the goals whose proof appears (as an
existential variable) in another goal).
The semi-colon in Ltac is implemented as the functional composition of
tactics. It is associative: t1;(t2;t3) is always exactly the same tactic as
(t1;t2);t3. But confusion arises from the fact that t1;[t2|…|tn] is not of
the form t1;t'.
To be clear, when you say that t1;(t2;t3) is always the same as
(t1;t2);t3, that's not the case when t3 is of the form [t3a|t3b|...], as
shown by this:
Goal forall (A B : Prop), A \/ B -> B.
intros A B H.
Fail (destruct H; idtac; [idtac|fail..]).
destruct H; (idtac; [idtac|fail..]).
Well, yes. But that's an ill-formed question. The sore core of the problem
that t;([t1|…|tn]) is not parsable. I could fix the problem by introducing
a syntax [t1|…|tn] and make it so that ; [ is parsed specially and that we
have to write t;([t1|…|tn]) to the the simple semantics. But I fear the
complaints would be loud.
Please do not change the semantics of the existing syntax. I am not requesting any such thing.
All that I am asserting is that it might be useful to have an alternative to [t1|...|tn] that behaves as does the current syntax in the "Fail (destruct...)" line in the above Goal, but also maintains that same behavior in the last line of the above Goal.
I don't seem to be able to come up with a case where || or + or progress,It's because it never even made sense before, and there are no tactics yet
combined with associativity, produces a Goal as counter-intuitive as the
one I gave above.
Maybe it is only t;[t1|...|tn] that would benefit from an alternative?
where it would show. But suppose we have a superauto which is capable of
sharing information between goals so as to solve more sets of goals than
auto (which treats all the input subgoals independently). Then it is
possible to cook an example where superauto would solve the goals, but try
superauto would not.
/Arnaud
Yes. I can certainly use such a superauto. Maybe it is better to introduce it as an alternative type of goal selector to "all:"? Perhaps "join:", so that one could write join: eauto, or create their own tactic that can make further progress towards a solution when given multiple goals together.
Then, it would work to define:
Ltac at_most_one := idtac;[idtac|fail..].
and use it as:
intros A B H.
destruct H.
Fail (join: at_most_one).
Although this creates more of a disparity between the script, which can use goal selectors, and tactics, which cannot. I am not sure that matters as much, though.
-- Jonathan
- Re: [Coq-Club] [coqdev] Tactic for detecting that there is a goal left?, (continued)
- Re: [Coq-Club] [coqdev] Tactic for detecting that there is a goal left?, Arnaud Spiwack, 06/13/2014
- Re: [Coq-Club] [coqdev] Tactic for detecting that there is a goal left?, Jonathan, 06/13/2014
- Re: [Coq-Club] [coqdev] Tactic for detecting that there is a goal left?, Arnaud Spiwack, 06/17/2014
- Re: [Coq-Club] [coqdev] Tactic for detecting that there is a goal left?, Jonathan, 06/17/2014
- Re: [Coq-Club] [coqdev] Tactic for detecting that there is a goal left?, Arnaud Spiwack, 06/18/2014
- Re: [Coq-Club] [coqdev] Tactic for detecting that there is a goal left?, Daniel Schepler, 06/18/2014
- Re: [Coq-Club] [coqdev] Tactic for detecting that there is a goal left?, Arnaud Spiwack, 06/19/2014
- Re: [Coq-Club] [coqdev] Tactic for detecting that there is a goal left?, Jonathan, 06/18/2014
