- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] [coqdev] Tactic for detecting that there is a goal left?
- Date: Fri, 13 Jun 2014 11:56:55 -0400
There are probably other cases where in "tac1; tac2" one would desire a single invocation of tac2 to act on all subgoals generated from tac1 instead of having a separate invocation of tac2 for each. Why not just have a syntax for that? Something like "tac1 > tac2" to suggest that all subgoals of tac1 are gathered into one call of tac2?
On 06/13/2014 11:46 AM, Arnaud Spiwack wrote:
Well, everyone would, I think. And of course, we'd need a tactic [t..] for
instance (currently it behaves like t, but I consider it a bug) to be able
apply t to each goal independently (so that the current a;[t1…tn] woud be
written [a;[t1…tn]..]).
However, I would say that pretty much every recursive tactic using ;[]
would fail (in fact, there are already several failure in Logic.v, the
first file in the standard library which calls tactics…). It is possible to
invent a new syntax of course… but not very desirable. I haven't taken a
decision.
Goal counting is easy. Of course, since Ltac doesn't have datatype, we'll
need to make special tactics and syntax for most use case. Do you have any
opinion on the design?
On 13 June 2014 17:40, Jason Gross
<jasongross9 AT gmail.com>
wrote:
Er, I meant to say "I guess I'd be ok with having [t1|t2|...|tn] really
mean all:[t1|t2|...|tn|idtac..]"
-Jason
On Fri, Jun 13, 2014 at 4:39 PM, Jason Gross
wrote:
How much code actually relies on this? That is, how much code would
break if you changed [t1|t2|...|tn] to mean, morally, all:[t1|t2|...|tn]?
But I guess that's wrong, because when I do something like "assert (True
/\ (True -> True)) by (split; [ exact I | exact (fun x => x) ]).", I want
it to apply only to the two given goals, and not fail because I have some
unknown number of other goals. I guess I'd be ok with having
[t1|t2|...|tn] really mean [t1|t2|...|tn|idtac..] (with some kind of flag
to restore the old behavior, maybe), and have a dedicated tactic for
"assert that there are {exactly,at most,no more than} n goals" (I guess
having a "count the number of goals and give me it as a nat" would also be
fine, since I could then write the assert tactic in ltac).
The bug tracker seems to be down now, but is someone willing to add such
a tactic/primitive in trunk?
On Fri, Jun 13, 2014 at 4:26 PM, Arnaud Spiwack
<arnaud AT spiwack.net>
wrote:
Well, at_most_one_goal_left will always succeed in the current semantics
(even all:at_most_one_goal_left). Also, solve[idtac] is equivalent to fail.
But I'm glad you are bringing that to the table. Because it is a sore
point in Ltac's behaviour. Point to the matter: (a;b);[t1…tn] doesn't mean
the same thing as a;(b;[t1…tn]). In the first case, [t1…tn] is applied to
the n goals generated by a;b. But the latter tactic will apply [t1…tn] to
the n goal generated by b, in each of the subgoals generated by a.
This is a real problem because: 1/ It probably cannot be changed (to
much code rely on it) 2/ It'd be really sweet to change it, if only because
I want to make a;[t1…tn] into the composition of a; and [t1…tn]. So that
the latter can be called as it's own *bona fide* tactic (with all: for
instance).
That being said, independently of the matter of dispatched tactics (as I
call them). It is easy to write a bunch of ML tactic, in trunk, which could
count the number of focused goals. Using Proofview.Goal.goals or, more
efficiently, by adding a primitive in Proofview (proofs/proofview.ml).
Arnaud
On 13 June 2014 17:11, Jason Gross
wrote:
Hi,
Is there a standard way of asking the question "are all goals solved?"
and "is there at most one goal left?" in Ltac?
I can use "; solve [ idtac ]" to mean "fail if there are any goals
left", and I have been using "; []" to detect "exactly one goal left", and
and I can define a tactic
Ltac at_most_one_goal_left := idtac; [].
so that "; at_most_one_goal_left" will fail if there is more than one
goal. But is seems poor that inlining a tactic definition changes its
behavior; am I simply exploiting a bug?
-Jason
- Re: [Coq-Club] Tactic for detecting that there is a goal left?, (continued)
- Re: [Coq-Club] Tactic for detecting that there is a goal left?, Adam Chlipala, 06/13/2014
- Re: [Coq-Club] Tactic for detecting that there is a goal left?, Jason Gross, 06/13/2014
- Re: [Coq-Club] Tactic for detecting that there is a goal left?, Jonathan, 06/13/2014
- Re: [Coq-Club] Tactic for detecting that there is a goal left?, Cedric Auger, 06/13/2014
- Re: [Coq-Club] [coqdev] Tactic for detecting that there is a goal left?, Arnaud Spiwack, 06/13/2014
- Re: [Coq-Club] [coqdev] Tactic for detecting that there is a goal left?, Jason Gross, 06/13/2014
- Re: [Coq-Club] [coqdev] Tactic for detecting that there is a goal left?, Jonathan, 06/13/2014
- Re: [Coq-Club] [coqdev] Tactic for detecting that there is a goal left?, Arnaud Spiwack, 06/17/2014
- Re: [Coq-Club] [coqdev] Tactic for detecting that there is a goal left?, Jonathan, 06/17/2014
- Re: [Coq-Club] [coqdev] Tactic for detecting that there is a goal left?, Arnaud Spiwack, 06/18/2014
- Re: [Coq-Club] [coqdev] Tactic for detecting that there is a goal left?, Daniel Schepler, 06/18/2014
- Re: [Coq-Club] [coqdev] Tactic for detecting that there is a goal left?, Arnaud Spiwack, 06/19/2014
- Re: [Coq-Club] [coqdev] Tactic for detecting that there is a goal left?, Jonathan, 06/18/2014
