- From: Pierre Courtieu <pierre.courtieu AT gmail.com>
- To: Coq Club <coq-club AT inria.fr>
- Cc: Bas Spitters <b.a.w.spitters AT gmail.com>
- Subject: Re: [Coq-Club] Automatic Indentation
- Date: Fri, 20 Jun 2014 17:10:51 +0200
Yes it does. This was implemented at about the same time bullets were
introduced in coq (actually it was implemented *before* to convince
dev team that bullets were a good idea :)).
I am not sure a release of pg was done since that however. Try dev
version of pg.
Beware that you need to follow the precedence - > +> * to make
indentation work. Nesting bullets inside { } is supported.
It is a bit fragile (sometimes very slow, sometimes (rarely) buggy)
but it works. It is not very customizable currently.
P.
2014-06-20 9:27 GMT+02:00 Julien Narboux
<jnarboux AT narboux.fr>:
> Hi Pierre,
> Is ProofGeneral indenting proofs ? the version I tried before posting this
> message was indenting only Lemma/Sections...
> Cheers,
> Julien
> 2014-06-20 1:38 GMT+02:00 Pierre Courtieu
> <pierre.courtieu AT gmail.com>:
>> Hi,
>> Note that proofgeneral has indentation working, use tab for a single
>> line and M-x indent-region for indenting a whole region (it may be
>> slow for big files with big modules of sections). bug reports welcome.
>> Best,
>> Pierre
>> 2014-06-19 16:31 GMT+02:00 Julien Narboux
>> > Thanks a lot it is almost what I need.
>> > I changed the indentation style. My version is available here:
>> > https://github.com/jnarboux/corn/blob/master/tools/coqindenter
>> > Julien
>> > 2014-06-18 16:28 GMT+02:00 Eelis van der Weegen
>> > <eelis AT eelis.net>:
>> >> Webpage should be up again now. The script has probably bit-rotted a
>> >> lot
>> >> though.
>> >> On 2014-06-18 14:50, Bas Spitters wrote:
>> >>> Eelis once worte:
>> >>> http://www.eelis.net/coqindent/
>> >>> It seems to be currently offline, but it is still on github:
>> >>> https://github.com/c-corn/corn/blob/master/tools/coqindenter
>> >>> On Tue, Jun 17, 2014 at 4:11 PM, Julien Narboux
>> >>> wrote:
>> >>>> Hi,
>> >>>> Does anyone have a script to automatically indent a Coq *proof* ?
>> >>>> I would like to add curly brackets {} and bullets to an existing
>> >>>> proof
>> >>>> to
>> >>>> group the tactics solving the same goal.
>> >>>> Cheers,
>> >>>> Julien Narboux
- [Coq-Club] Automatic Indentation, Julien Narboux, 06/17/2014
- Re: [Coq-Club] Automatic Indentation, Bas Spitters, 06/18/2014
- Re: [Coq-Club] Automatic Indentation, Eelis van der Weegen, 06/18/2014
- Re: [Coq-Club] Automatic Indentation, Julien Narboux, 06/19/2014
- Re: [Coq-Club] Automatic Indentation, Pierre Courtieu, 06/20/2014
- Re: [Coq-Club] Automatic Indentation, Julien Narboux, 06/20/2014
- Re: [Coq-Club] Automatic Indentation, Strub, Pierre-Yves, 06/20/2014
- Re: [Coq-Club] Automatic Indentation, Pierre Courtieu, 06/23/2014
- Re: [Coq-Club] Automatic Indentation, Stefan Monnier, 06/23/2014
- Re: [Coq-Club] Automatic Indentation, Jonathan, 06/20/2014
