- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Automatic Indentation
- Date: Fri, 20 Jun 2014 11:50:16 -0400
On 06/20/2014 11:10 AM, Pierre Courtieu wrote:
Yes it does. This was implemented at about the same time bullets were
introduced in coq (actually it was implemented *before* to convince
dev team that bullets were a good idea :)).
I am not sure a release of pg was done since that however. Try dev
version of pg.
Beware that you need to follow the precedence - > +> * to make
indentation work. Nesting bullets inside { } is supported.
It is a bit fragile (sometimes very slow, sometimes (rarely) buggy)
but it works. It is not very customizable currently.
P.
Beware that sometimes PG's indenter (even the most recent dev version, which I use) makes some unusual choices, probably due to trying to cope with the new bullets syntax. For instance:
intros.
tac.
gets re-indented as follows, but only when certain bullet-esque intro patterns are used:
intros x **.
tac.
[In case e-mail formatting throws that off - the tac on the second line is lined up under x.]
-- Jonathan
- [Coq-Club] Automatic Indentation, Julien Narboux, 06/17/2014
- Re: [Coq-Club] Automatic Indentation, Bas Spitters, 06/18/2014
- Re: [Coq-Club] Automatic Indentation, Eelis van der Weegen, 06/18/2014
- Re: [Coq-Club] Automatic Indentation, Julien Narboux, 06/19/2014
- Re: [Coq-Club] Automatic Indentation, Pierre Courtieu, 06/20/2014
- Re: [Coq-Club] Automatic Indentation, Julien Narboux, 06/20/2014
- Re: [Coq-Club] Automatic Indentation, Strub, Pierre-Yves, 06/20/2014
- Re: [Coq-Club] Automatic Indentation, Pierre Courtieu, 06/23/2014
- Re: [Coq-Club] Automatic Indentation, Stefan Monnier, 06/23/2014
- Re: [Coq-Club] Automatic Indentation, Jonathan, 06/20/2014
