coq-club - Re: [Coq-Club] Navigation shortcuts for CoqIDE in Windows 7
  • From: Marcus Ramos <marcus.ramos AT univasf.edu.br>
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Navigation shortcuts for CoqIDE in Windows 7
  • Date: Mon, 23 Jun 2014 15:06:00 +0200
Hi Chris,
Thanks a lot for your config file, now I can use shortcuts on Windows. I also tried pl4, but it still doesn´t work.
Best Regards,
Marcus.
2014-06-18 21:55 GMT+02:00 Christopher Ernest Sally <christopherernestsally AT gmail.com>:
Hey Marcus
Yeah, it was an annoying problem that was around for a while. (At the very least, all the windows ppl in my group suffered from it.) It should be gone in pl4, but if not, what you have to do is create a config file in a folder
Follow these instructions.
http://coq.inria.fr/cocorico/Configuration%20of%20CoqIDE
(you may have to try dropping it in several folders depending on your environment)
I also include a my config file for you as a template, 'cos I was never able to get one off cocorico.
Best
Chris
On 17 June 2014 19:15, Marcus Ramos <marcus.ramos AT univasf.edu.br> wrote:
Hi,
I am using CoqIDE 8.4pl3 in Windows 7, but shortcuts for navigation keys simply don´t work. Not even if I change the modifiers in the Preferences panel. Any idea on how to fix this? Or is it a bug?
Thanks,
Marcus.
