coq-club - Re: [Coq-Club] Remove or update a canonical structure registration?
  • From: "Strub, Pierre-Yves" <pierre-yves AT strub.nu>
  • To: coq-club AT inria.fr
  • Cc: Peng Wang <wangp.thu AT gmail.com>
  • Subject: Re: [Coq-Club] Remove or update a canonical structure registration?
  • Date: Mon, 23 Jun 2014 11:37:44 +0200
Hi,
One way to work around this is to define your canonical structure on an alias of your type. See for example the left-module canonical structure for rings when these last are acting on themselves (Search for the notation "R ^o" in ssralg.v). You then have to give some type annotation, e.g.:
Goal forall (R : ringType) (x y : {poly R}^o), x *: y = x * y.
choose the wanted lmodule structure for {poly R}. Note that R^o is convertible to R.
Best,
-- Pierre-Yves.
On 2014-06-18 00:56, Peng Wang wrote:
Is there a way to remove or update a canonical structure registration?
For example, SSReflect's matrix.v registers a canonical structure
matrix_lmodType to declare that ring-element matrices form an L-module
whose scalars are of the same type as the elements. But for
algebra-element matrices, there is another way to form an L-module,
where scalars are from the underlying ring of the algebra. I want to
register this alternative L-module structure to be canonical (e.g. to
talk about "a matrix of functions scaled by a constant"), but Coq's
Canonical Structure command only respects the first registration and
ignores later ones.
