coq-club - Re: [Coq-Club] Why do section variables behave differently in a definition than its arguments with respect to tactics?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Why do section variables behave differently in a definition than its arguments with respect to tactics?
  • Date: Wed, 25 Jun 2014 11:20:06 -0400
On 06/25/2014 03:46 AM, Cedric Auger wrote:
I already reported a probably related bug in 2010:
https://coq.inria.fr/bugs/show_bug.cgi?id=2243
It was about destruct and not clear.
That is even stranger, as it won't allow the section variable to be destructed prior to renaming it. Or, rather, that the original name is tied to some unseen dependency. For instance, I tried this with your test case: revert H; intro L; revert L; intro H; destruct H. - and it still fails the same way: "Error: H is used in hypothesis i." Even this sequence fails in your setup:
revert H.
assert (H:True) by constructor.
destruct H; clear H. (* shows H:True can be destructed *)
intro H.
destruct H. (*fails*)
Also, if one removes the "Section 0" line, forcing the variables to become local definitions, then the destruct works.
In the case I reported, I was able to destruct the variable as long as I did so by only introducing new ids. I was able to verify that my case occurs with destruct as well as induction.
I guess I should restrict usage of section variables until this is fixed...
-- Jonathan
