coq-club - Re: [Coq-Club] Ending a section and its dependency analysis of global objects in it
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Ending a section and its dependency analysis of global objects in it
  • Date: Wed, 25 Jun 2014 11:52:23 -0400
On 06/25/2014 02:29 AM, Guillaume Melquiond wrote:
On 24/06/2014 23:53, Jonathan wrote:
Could someone describe in more detail what is supposed to go on at the
end of a section with regard to this dependency analysis? I might be
seeing a bug, or I might just not understand what is involved in a
dependency according to this analysis. Is it perhaps that some tactics
involved in the proof of the definition create "false" dependencies that
aren't really needed, but are still honored with respect to
end-of-section dependency analysis?
As long as the hypotheses appear in the constructed proof terms, they are actual dependencies. You can Print the proved theorems to see where they come from. Do you happen to use any automatic tactic (auto, omega, assumption, etc)? Such tactics don't try to find the minimal subset of hypotheses needed for proving a goal. And even if they were doing this extra work locally, that would not guarantee that the whole theorem would use a minimal subset of hypotheses.
Best regards,
Guillaume
Yes, the set of tactics used includes various automation tactics - so it is not surprising that the dependencies are formed.
The other issues with section variables being discussed make it unlikely that using Section in the way I described (turning a goal into a separate definition) would work anyway.
But, if that other bug was fixed - it might be possible to create a Section from a goal, prove the consequent in that section as a definition, and then automatically one at a time delete the variables to see which ones can be removed without altering the proof...
-- Jonathan
