coq-club - Re: [Coq-Club] Purging a script of auto-named variables
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Purging a script of auto-named variables
  • Date: Wed, 2 Jul 2014 11:07:56 +0200
There is a command "Show intros" to display the names which will be generated. It is possible to build a script which replace intros. intos named intros, a good starting point for writing such a script could be the one for indenting writen by Eelis:
https://github.com/jnarboux/corn/blob/master/tools/coqindenter
We could have also an option to prevent you from using automatically named variables (the prefix could be something like a utf8 character for space). I think this is the default behaviour in Isabelle/Isar.
Julien
2014-06-30 21:08 GMT+02:00 Jonathan <jonikelee AT gmail.com>:
I've been getting careless and not carefully naming all variables in a proof script myself.  Is there any mechanism that can help one to rework a proof script so that all of the variables used in tactics are not of the automatically-named variety?
For instance, is there some mechanism in Coq that would alter the automatic naming in a predictable way - say by appending a user-provided suffix to each automatically generated name?  A "Set Auto Naming Suffix" command?  Given that, I could provide some easily distinguishable suffix like "__" (double underscore), and rerun a script to see where it fails - and clean up the instances one by one.
This became a bit more important recently, as there was something introduced into the trunk version of Coq that slightly changed the automatic naming scheme in certain cases.
-- Jonathan
