- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Purging a script of auto-named variables
- Date: Wed, 02 Jul 2014 08:00:42 -0400
On 07/02/2014 05:07 AM, Julien Narboux wrote:
There is a command "Show intros" to display the names which will be
generated.
I already use PG's ^C^ATab, which uses Show intros to automatically generate a completely named intro pattern. But there are many more tactics that introduce names - some of which it's quite hard to control (inversion is an example).
It is possible to build a script which replace intros. intos
named intros, a good starting point for writing such a script could be the
one for indenting writen by Eelis:
https://github.com/jnarboux/corn/blob/master/tools/coqindenter
I will look at your script.
We could have also an option to prevent you from using automatically named
variables (the prefix could be something like a utf8 character for space).
I think this is the default behaviour in Isabelle/Isar.
I suggested a suffix so as not to interfere with the "fresh" tactic, which sets the prefix - in other words, setting a suffix would cause fresh to obey that suffix without changing its current semantics - since it is already allowed to choose a suffix to keep the name fresh.
Otherwise, this is similar to what I suggested - although I'd rather that the prefix/suffix did print visibly, so that the change could be seen.
As for using this to prevent one from using automatically named variables instead of allowing one to fix them later: when working on a proof, I don't want to work too hard on preventing automatic names and as a result lose my train of thought on the proof itself. I think I'd rather go back after finishing the proof, and fix it.
-- Jonathan
Julien
2014-06-30 21:08 GMT+02:00 Jonathan
<jonikelee AT gmail.com>:
I've been getting careless and not carefully naming all variables in a
proof script myself. Is there any mechanism that can help one to rework a
proof script so that all of the variables used in tactics are not of the
automatically-named variety?
For instance, is there some mechanism in Coq that would alter the
automatic naming in a predictable way - say by appending a user-provided
suffix to each automatically generated name? A "Set Auto Naming Suffix"
command? Given that, I could provide some easily distinguishable suffix
like "__" (double underscore), and rerun a script to see where it fails -
and clean up the instances one by one.
This became a bit more important recently, as there was something
introduced into the trunk version of Coq that slightly changed the
automatic naming scheme in certain cases.
-- Jonathan
- Re: [Coq-Club] Purging a script of auto-named variables, Julien Narboux, 07/02/2014
- Re: [Coq-Club] Purging a script of auto-named variables, Jonathan, 07/02/2014
- Re: [Coq-Club] Purging a script of auto-named variables, Pierre Courtieu, 07/02/2014
