coq-club - Re: [Coq-Club] How to use new -R option properly?
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] How to use new -R option properly?
  • Date: Sat, 12 Jul 2014 18:34:44 +0200
Le samedi 12 juillet 2014, Jonathan <jonikelee AT gmail.com> a écrit :
After pulling the latest trunk version, I had to fix up several things.  One was trying to guess how this -R option to coqdep works if I just want a single directory project.  I guessed this: -R . ""
I guess the name of your package instead of "" would work just as well. The point of this -R is to make packages relocatable but inside your project you can still use unqualified imports.
That seems to have made make happy, but is it right?
Also, the automatic naming of hypotheses rules were switched again! I guess I really need some approach that will allow me to comb through my proofs to find references to automatically named hypotheses.  Although, pulling changes to the naming rules is a start ;)
There is an option Set Standard Proposition Elimination Names (or similar, Print Options will tell you) to change this behavior.
Best,
-- Matthieu
