- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] How to use new -R option properly?
- Date: Sat, 12 Jul 2014 13:10:10 -0400
On 07/12/2014 12:34 PM, Matthieu Sozeau wrote:
Le samedi 12 juillet 2014, Jonathan
<jonikelee AT gmail.com>
a écrit :
After pulling the latest trunk version, I had to fix up several things.
One was trying to guess how this -R option to coqdep works if I just want
a single directory project. I guessed this: -R . ""
I guess the name of your package instead of "" would work just as well. The
point of this -R is to make packages relocatable but inside your project
you can still use unqualified imports.
OK. If I use the name of the package, will that be needed as a prefix in Require commands? In other words, if I change from -R . "" to -R . Foo, do I also have to change all occurrences of Require somelocalfile to Require Foo.somelocalfile? Or, is the local directory still searched, and so no prefix is needed for local files?
Also, the automatic naming of hypotheses rules were switched again! I
guess I really need some approach that will allow me to comb through my
proofs to find references to automatically named hypotheses. Although,
pulling changes to the naming rules is a start ;)
There is an option Set Standard Proposition Elimination Names (or similar,
Print Options will tell you) to change this behavior.
Best,
-- Matthieu
Could you point me to the place in the ML sources for Coq where the naming behavior is controlled? I am wondering how hard it would be to put in that add-a-suffix scheme I proposed two weeks ago as a way to help find uses of automatic names in proof scripts. I really don't want to depend on any automatic naming convention - it is just too hard right now to find all instances of usage of automatically named variables in a long proof script, and also too inconvenient to make sure in advance one doesn't use them.
-- Jonathan
- [Coq-Club] How to use new -R option properly?, Jonathan, 07/12/2014
- Re: [Coq-Club] How to use new -R option properly?, Matthieu Sozeau, 07/12/2014
- Re: [Coq-Club] How to use new -R option properly?, Jonathan, 07/12/2014
