coq-club - [Coq-Club] can't implement a simple function with certified type
  • To: coq club <coq-club AT inria.fr>
  • Subject: [Coq-Club] can't implement a simple function with certified type
  • Date: Sun, 13 Jul 2014 02:26:48 +0300
Hi all,
I'm trying to implement a somewhat certified version of a very simple
function and I'm very confused.
The function is this: reverse a list at given index. For example,
`rev_at 1 [1; 2; 3; 4]` should return `[1; 4; 3; 2]`.
I want to have a type that 1) ensures that given index < length of
list 2) return value is of same length with the argument.
Here's what I tried.
First, I implemented a simply typed version and then wrapped it with
precisely typed version:
Fixpoint rev_at_aux {A} (l : list A) idx : list A :=
match idx with
| 0 => rev l
| S idx' =>
match l with
| h :: t => h :: rev_at_aux t idx'
end
end.
Definition rev_at {A} (l : list A) idx (p : idx < length l) : list A :=
rev_at_aux l idx.
Now this definition works fine but it's missing (2). For that I
modified the definition:
Definition rev_at' {A} (l : list A) idx (p : idx < length l) : {l' :
list A | length l' = length l}.
apply exist with (x := rev_at l idx p). unfold rev_at. unfold
rev_at_aux. induction idx as [|idx'].
+ (* I'm stuck, I have a fix application and I can't use simpl. *)
Abort.
But I have no idea how to implement this. I tried refine but I never
managed to use that as mentioned below.
I know I can prove a theorem saying that `length (rev_at l idx p) = length l`:
Require Import Omega.
Theorem rev_at_l : forall A l idx p, length (@rev_at A l idx p) = length l.
Proof.
intros. generalize dependent idx. induction l as [|h t]; intros.
+ destruct idx; auto.
+ destruct idx as [|idx'].
- unfold rev_at. unfold rev_at_aux. apply rev_length.
- simpl in p. assert (idx' < length t). omega.
simpl. f_equal. apply IHt with (p := H).
Qed.
But for learning purposes, I'd like to implement this without
implementing theorems separately.
Second, I tried using vectors:
Require Vector.
Definition rev_at'' : forall A len (v : Vector.t A len) (idx : nat)
(p : idx < len), Vector.t A len.
refine (fix f A len v idx p :=
match v with
| Vector.nil => Vector.nil
| Vector.cons h len' t => _
end).
.. and I failed again. I never managed to use refine for anything
useful. In this case, I'm getting this weird type error:
Error: The term
"fix f (A : ?548) (len : ?549) (v : Vector.t ?556 ?557) (idx : ?551)
(p : ?552) {struct v} : forall A0 : Type, Vector.t A0 ?570 :=
match
v as v0 in (Vector.t _ n) return (forall A0 : Type, Vector.t A0 ?570)
with
| [] => Vector.nil
| Vector.cons h len' t => ?568
end" has type
"forall (A : ?548) (len : ?549) (v : Vector.t ?556 ?557) (idx : ?551)
(p : ?552) (A0 : Type), Vector.t A0 ?570"
while it is expected to have type
"forall (A : Type) (len : nat),
Vector.t A len -> forall idx : nat, idx < len -> Vector.t A len".
If I replace first case with underscore, it works(what's wrong with
current version?) but then I can't prove goals because there are lost
information. For example, in second case, I don't have `len = S len'`
or `v = Vector.cons h len' t`. I'm trying to figure out how to use
refine for some long time now but I never understand how to do
anything useful with all the information lost when refine is used.
So I'm stuck and confused. Can anyone help me defining this?
Thanks.
Ömer Sinan Ağacan
http://osa1.net
