coq-club - Re: [Coq-Club] assert in a ltac match
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] assert in a ltac match
  • Date: Tue, 15 Jul 2014 10:16:33 +0200
Hi Michael,
One way to do this is by using "assert by”, as you mentioned. But what
follows the “by" must be a complete proof. Furthermore, note that the “;”
operator has a higher precedence in parsing than “by” in "assert by” clause.
As a result, you have to use parentheses to override the precedence.
Therefore, the following ltac should work:
match goal with
H1: (?a->?b) /\ (_->_), H2: ?a |- _ => assert(b) by (apply H1; exact H2)
end.
Regards,
Amin
On 15 Jul 2014, at 10:03,
michael.soegtrop AT intel.com
wrote:
> Dear Coq users,
> I want to do an assert as result of a ltac match and immediaetly resolve it
> with hypothesis I found in the match, but somehow I can't find the right
> syntax. Please have a look at the example below:
> Parameter A B C D E: Prop.
> Lemma Test1: A -> (A->B) /\ (C->D) -> E.
> Proof.
> intros.
> match goal with
> end.
> I want to resolve the assert by applying H1 and H2, but chaining with ;
> doesn't work for assert, because the chained tactics still apply to the goal
> before the assert was issued and not the goal created by the assert. assert
> seems to require . but this doesn't work in a match.
> Also I can't get this to work with variations of assert by H1;H2.
> I frequently do somethign like assert(AH:=H1 H2), but this doesn't work
> cause
> of the conjunction in this case. Is there a way to get e.g. the left part of
> H1 on the fly (without doing an inversion).
> What does work is doing an inversion on H1, match HL with the left part of
> H1
> and use assert(AH:=HL H2), but this is way complicated. Also in the actual
> case there are quantifiers in the hypothesis, so that inversion doesn't
> work.
> What is the best way of doing this?
> Thanks & best regards,
> Michael
