coq-club - RE: [Coq-Club] assert in a ltac match
  • From: "Soegtrop, Michael" <michael.soegtrop AT intel.com>
  • To: "coq-club AT inria.fr" <coq-club AT inria.fr>
  • Subject: RE: [Coq-Club] assert in a ltac match
  • Date: Tue, 15 Jul 2014 09:08:41 +0000
  • Accept-language: de-DE, en-US
Dear Amin,
thanks, this works! I thought I tried this, but looks like I had some typo in
it.
Best regards,
Michael
-----Original Message-----
coq-club-request AT inria.fr
[mailto:coq-club-request AT inria.fr]
On Behalf Of Amin Timany
Sent: Tuesday, July 15, 2014 10:17 AM
To:
Subject: Re: [Coq-Club] assert in a ltac match
Hi Michael,
One way to do this is by using "assert by", as you mentioned. But what
follows the "by" must be a complete proof. Furthermore, note that the ";"
operator has a higher precedence in parsing than "by" in "assert by" clause.
As a result, you have to use parentheses to override the precedence.
Therefore, the following ltac should work:
match goal with
H1: (?a->?b) /\ (_->_), H2: ?a |- _ => assert(b) by (apply H1; exact H2)
end.
Regards,
Amin
On 15 Jul 2014, at 10:03,
wrote:
> Dear Coq users,
> I want to do an assert as result of a ltac match and immediaetly
> resolve it with hypothesis I found in the match, but somehow I can't
> find the right syntax. Please have a look at the example below:
> Parameter A B C D E: Prop.
> Lemma Test1: A -> (A->B) /\ (C->D) -> E.
> Proof.
> intros.
> match goal with
> H1: (?a->?b) /\ (_->_), H2: ?a |- _ => assert(b) end.
> I want to resolve the assert by applying H1 and H2, but chaining with
> ; doesn't work for assert, because the chained tactics still apply to
> the goal before the assert was issued and not the goal created by the
> assert. assert seems to require . but this doesn't work in a match.
> Also I can't get this to work with variations of assert by H1;H2.
> I frequently do somethign like assert(AH:=H1 H2), but this doesn't
> work cause of the conjunction in this case. Is there a way to get e.g.
> the left part of
> H1 on the fly (without doing an inversion).
> What does work is doing an inversion on H1, match HL with the left
> part of H1 and use assert(AH:=HL H2), but this is way complicated.
> Also in the actual case there are quantifiers in the hypothesis, so that
> inversion doesn't work.
> What is the best way of doing this?
> Thanks & best regards,
> Michael
