- From: Pierre Letouzey <pierre.letouzey AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Errors in extracted program.
- Date: Tue, 15 Jul 2014 14:34:39 +0200 (CEST)
----- Mail original -----
> This leads me to the second part of your report, which is far more severe:
> something informative (in Coq's type "sum") is suddenly considered as
> logical by the system (i.e. acceptable in sort "Prop"), and hence discarded
> by the extraction, leading to this faulty "match __ with ...". This is
> normally impossible in the good old theory of Coq, but this theory around
> universes has been so much tweaked in the recent years (Hugo) and months
> (Matthieu) that the very foundational principles of extraction need to be
> re-asserted, and probably adapted, as shown by this bug. Once again, I'll
> let you know when I know more.
> Best regards,
> Pierre Letouzey
Hi again
The "sum" instance being in "Prop" was actually a bug, now fixed in coq trunk
by Matthieu (commit 2b833c49). Since this commit, your development needs to be
slightly adapted accordingly :
- in Prefix.prefix_common you cannot inverse an "exists" to build
a "sum", now that this "sum" isn't in Prop anymore.
- in Combi, a few "H" are now "X"
- in DeflateCoding, a few "sum" should rather be some "or" now.
Here comes a temptative patch. With it, things compile and extract nicely
(even if I've still the issue with Vector.t/VectorDef.t to investigate).
Best regards
Pierre
diff --git a/Combi.v b/Combi.v index ecacabc..0d7c5c3 100644 --- a/Combi.v +++ b/Combi.v @@ -1134,7 +1134,7 @@ Proof. assert (dc: {n | ~ Q (Vnth e n)} + ({n | ~ Q (Vnth e n)} -> False)). apply (dec_in_dec _ (fun n => ~ Q n)). intros a. - elim (H a). + elim (X a). intros Qa. apply inr. auto. intros nQa. @@ -1151,7 +1151,7 @@ Proof. apply inl. apply forall_notexists. intros a. - apply H. + apply X. apply nex. Defined. diff --git a/DeflateCoding.v b/DeflateCoding.v index 1ce5902..c76921a 100644 --- a/DeflateCoding.v +++ b/DeflateCoding.v @@ -1019,7 +1019,7 @@ Proof. apply b1_lt_a1. Defined. -Lemma sorting_rmdup : forall n L, Sorted (fun x y => ((x = y) + (mys (n:=n) x y))%type) L -> +Lemma sorting_rmdup : forall n L, Sorted (fun x y => ((x = y) \/ (mys (n:=n) x y))%type) L -> Sorted mys (rmdup L). Proof. intros n L. @@ -1064,7 +1064,7 @@ Theorem sorting : forall {n} (L : list (fin n * nat)), {L' | StronglySorted mys L' /\ forall x, In x L <-> In x L'}. Proof. intros n L. - assert (xL : {L' | (forall x, In x L <-> In x L') /\ Sorted (fun x y => ((x = y) + (mys x y))%type) L'}). + assert (xL : {L' | (forall x, In x L <-> In x L') /\ Sorted (fun x y => ((x = y) \/ (mys x y))%type) L'}). apply Quicksort.quicksort. intros a b. @@ -1073,15 +1073,15 @@ Theorem sorting : forall {n} (L : list (fin n * nat)), elim eq_mysab. intros a_eq_b. apply left. - apply inl. + apply or_introl. apply a_eq_b. intros mysab. apply left. - apply inr. + apply or_intror. apply mysab. intros mysba. apply right. - apply inr. + apply or_intror. apply mysba. elim xL. diff --git a/Prefix.v b/Prefix.v index f5b935e..439d3a8 100644 --- a/Prefix.v +++ b/Prefix.v @@ -158,94 +158,32 @@ Lemma prefix_common : forall a b c, prefix a c -> prefix b c -> Proof. refine (fix pc a b c ac bc := match (a, b, c) as A return ((a, b, c) = A -> _) with - | (nil, b, _) => fun eq => _ + | (nil, _, _) => fun eq => _ | (xa :: xA, nil, _) => fun eq => _ - | (xa :: nil, xb :: xB, _) => fun eq => _ - | (xa :: ya :: xA, xb :: nil, _) => fun eq => _ - | (xa :: ya :: xA, xb :: yb :: xB, nil) => fun eq => _ - | (xa :: ya :: xA, xb :: yb :: xB, xc :: nil) => fun eq => _ - | (xa :: ya :: xA, xb :: yb :: xB, xc :: yc :: xC) => fun eq => _ + | (xa :: xA, xb :: xB, nil) => fun eq => _ + | (xa :: xA, xb :: xB, xc :: xC) => fun eq => _ end eq_refl). + inversion eq. apply inl. exists b. auto. - inversion eq. - apply inr. - exists (xa :: Bnil). - apply app_nil_l. inversion eq. - apply inl. - exists xB. - inversion ac. - inversion bc. - - rewrite <- H3 in H. - rewrite -> H0 in H. - rewrite -> H1 in H. - inversion H. - reflexivity. - apply inr. - inversion eq. - exists (xa :: b0 :: l2). + exists (xa :: xA). apply app_nil_l. - inversion eq. - apply inr. - inversion ac. - inversion bc. - rewrite <- H3 in H. - rewrite -> H0 in H. - rewrite -> H1 in H. - inversion H. - exists (ya :: xA). - reflexivity. - - inversion eq. - inversion ac. - rewrite -> H0 in H. - rewrite -> H2 in H. - inversion H. - inversion eq. - inversion ac. - rewrite -> H2 in H. - rewrite -> H0 in H. - inversion H. + exfalso. + inversion eq. subst. + eapply prefix_nnil; eauto. - inversion eq. + inversion eq. subst. + assert (xa = xc). + { destruct ac as (xA',ac). simpl in *. now injection ac. } + assert (xb = xc). + { destruct bc as (xB',bc). simpl in *. now injection bc. } assert (rec : prefix xA xB + prefix xB xA). - apply pc with xC. - inversion ac. - rewrite -> H0 in H. - rewrite -> H2 in H. - inversion H. - exists x. - reflexivity. - inversion bc. - rewrite -> H1 in H. - rewrite -> H2 in H. - inversion H. - exists x. - reflexivity. - inversion ac. - inversion bc. - rewrite <- H3 in H. - rewrite -> H0 in H. - rewrite -> H1 in H. - inversion H. - elim rec. - intros preab. - apply inl. - inversion preab. - exists x1. - rewrite <- H4. - reflexivity. - intros preba. - apply inr. - inversion preba. - exists x1. - rewrite <- H4. - reflexivity. -Defined. \ No newline at end of file + { apply pc with xC; eapply prefix_cdr; eauto. } + destruct rec; [left|right]; subst; now apply prefix_cons. +Defined. diff --git a/deflate.v b/deflate.v index 88eab20..e6dbd4c 100644 --- a/deflate.v +++ b/deflate.v @@ -47,6 +47,8 @@ Defined. Definition fc1 := to_list (n:=(M (proj1_sig fixed_code))) (C (proj1_sig fixed_code)). +Extraction "fc1.ml" fc1. + Extraction Language Haskell. Recursive Extraction fc1. (* Fails *)
- [Coq-Club] Errors in extracted program., Christoph-Simon Senjak, 07/02/2014
- Re: [Coq-Club] Errors in extracted program., Pierre Letouzey, 07/11/2014
- Re: [Coq-Club] Errors in extracted program., Pierre Letouzey, 07/15/2014
- Re: [Coq-Club] Errors in extracted program., Christoph-Simon Senjak, 07/19/2014
