- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] question about rewrite dbs and autorewrite
- Date: Tue, 15 Jul 2014 14:24:56 -0400
In a single autorewrite db, if there are two or more rewrite hints that can be applied to a particular term, does autorewrite do any kind of ordering to decide which one to use (first)? Or, does it base the selection on the order in which the hints were registered in the db? Or, is it just random?
I am writing a system of rewrite rules, and some of them have specific applicability while others are default rules - and I would prefer the specific rules to fire if possible before the defaults (just for efficiency reasons - it should be a confluent system regardless). For instance, a specific rule that rewrites Foo(a::as) to Bar and a default that rewrites Foo(l) to Baz, where l is any list. I could put them into separate autorewrite dbs and chain them with autorewrite with DB1 DB2 ... DBN, but then it looks like I would also need to wrap the whole thing in a repeat/progress loop, like so:
repeat progress (autorewrite with DB1 DB2 ... DBN)
at least if I am understanding the description in refman section 8.8.4. Or, does autorewrite automatically loop back to try DB1 itself when it has exhausted DBN and the subgoal has progressed?
-- Jonathan
- [Coq-Club] question about rewrite dbs and autorewrite, Jonathan, 07/15/2014
