coq-club - Re: [Coq-Club] Question about proof with single negation and equality
  • From: Pierre Courtieu <pierre.courtieu AT gmail.com>
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Question about proof with single negation and equality
  • Date: Tue, 22 Jul 2014 12:57:06 +0200
014-07-22 11:57 GMT+02:00 Cedric Auger
<sedrikov AT gmail.com>:
> 2014-07-22 11:08 GMT+02:00 Pierre Courtieu
> <pierre.courtieu AT gmail.com>:
>> Be warned that in Coq the two versions are far from being equivalent.
>> Your version is indeed probably inconsistent for most instances of F.
>> You should definitely favor Cédric's one. In one word: your version
>> states that the proofs of equalities are *equal* whereas Cédric's one
>> only states that they can be derived from each other.
> Not exactly, it says that the statements are equal, it does not say much on
> the proofs.
Right, it is even more wrong then.
> In fact decidability won’t help much I fear. Decidability helps for "∀ (x y
> : A) (p q : x = y), p = q" which not what we have here, or so it seems to
> me.
Combined with the axiom A it does, as shown by the proof below. But
Arnaud gave a better solution.
P.
>> Variable C N: Set.
>> Variable F: C-> N.
>> Axiom A: forall c c': C, (~ (c = c')) <-> (~ (F c = F c')).
>> Axiom Cdec: forall c c':C, { c=c' } + { c<>c' } .
>> Theorem T: forall (n: N) (c: C), F c = n -> forall c': C, F c' = n -> c =
>> c'.
>> Proof.
>> intros n c H c' H0.
>> destruct (Cdec c c').
>> - assumption.
>> - rewrite <- H in H0.
>> assert (F c <> F c').
>> { apply A.
>> assumption. }
>> symmetry in H0.
>> contradiction.
>> Qed.
