- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Dot-qualifying
- Date: Thu, 24 Jul 2014 10:26:29 +0200
Oh, and did you try the coq_makefile utility ? (not sure of the name)
Maybe it could help you to understand the compilation mechanism of Coq.
2014-07-24 9:54 GMT+02:00 Kirill Taran <kirill.t256 AT gmail.com>:
Hello,
I tried to do simplest project with possibility to access modules via dot-notation:
$ mkdir A
$ touch A/B.v
$ echo "Require Import A.B." >> C.v
And I try "coqc -I A C.v", "coqc -I A -as A C.v"
and "coqc -R A A C.v", but without success.
Either I don't understand how to do it or there is no info about it.
There is whole section in reference manual, but I didn't succeed.
I tried to look at Coq sources for example, but I didn't figure out how it is done.
I guess that dot-notation is established with external option like -R, but don't understand how.Sincerely,
Kirill Taran
.../Sedrikov\...
- [Coq-Club] Dot-qualifying, Kirill Taran, 07/24/2014
- Re: [Coq-Club] Dot-qualifying, Cedric Auger, 07/24/2014
- Re: [Coq-Club] Dot-qualifying, Pierre-Evariste Dagand, 07/24/2014
- Re: [Coq-Club] Dot-qualifying, Kirill Taran, 07/24/2014
- Re: [Coq-Club] Dot-qualifying, Cédric, 07/25/2014
- Re: [Coq-Club] Dot-qualifying, Vladimir Voevodsky, 07/25/2014
