- To: coq-club AT inria.fr
- Cc: "Prof. Vladimir Voevodsky" <vladimir AT ias.edu>
- Subject: Re: [Coq-Club] Dot-qualifying
- Date: Fri, 25 Jul 2014 14:51:09 +0400
There is a very useful command "Print Load Path."
V.
On Jul 25, 2014, at 2:45 AM, Cédric <sedrikov AT gmail.com> wrote:
Le Thu, 24 Jul 2014 21:26:05 +0200, Kirill Taran <kirill.t256 AT gmail.com> a écrit:Cedric,
Yes, that is true. But my question is about other:
I have done "coqc -I A -as A A/B.v" and "coqc C.v", where C.v contains "Require Import A.B."
And these commands suceeded, so latter command "coqc C.v" sees file A/B.v.
The question is: "How does "coqc C.v" see A/B.v without providing loadpath?".
Does coqc look into subdirectories for compiled files?As far as I can remember, by default, loadpath contains '.' and the coq standard library. I think it is the case for many languages. Then if you have a X.vo file at dir1/dir2, the system allows to reference X as dir1.dir2.X (well, you still need to Require it of course.)Sincerely,
Kirill TaranOn Thu, Jul 24, 2014 at 4:38 PM, Cedric Auger <sedrikov AT gmail.com> wrote:2014-07-24 12:13 GMT+02:00 Kirill Taran <kirill.t256 AT gmail.com>:> But it's probably wiser to use coq_makefile to have these things
generated for you.
Agree, I just wanted to get knowledge about the principle.
> Maybe it could help you to understand the compilation mechanism of Coq.
Yep, I hadn't recalled about this, I could generate Makefile and explore it for the proper commands.
By the way, I don't understand fully the principle:
When I type "coqc C.v", how does coqc determine that it must look into directory "A"?
If it just uses logic "A.B means A/B.v" then why do we need this stuff with "-I A -as A"?
I haven’t compiled projects for some time, but as far as I can remember, compiling a file needs "loadpaths", that is a set of directory considered as root for Coq.
Basically, that is what "AddLoadPath" (inside of files) or "-I" (inside of command line) is for.
"AddLoadPath" is useful when developing a short project and you do not want to write a Makefile, or change it each time you add/remove files.
Still it has portability issues (case sensitiveness and '/' vs '\' according to Windows vs Posix conventions), thus once you want to publish your project, you should use only the "-I" command line option.
Several paths can be set as the Coq root (useful to have both the standard library and your project files available).
If I remember well, in your case, instead of "-I A -as A" you could also have used "-I ." ("adds current directory to loadpath"). It would have been slightly different though: you would also have loaded all other directories than A.
And using "-I A" would have been different of "-I A -as A", as module B would have been considered at top level ("Require B." rather than "Require A.B.").
Sincerely,
Kirill TaranOn Thu, Jul 24, 2014 at 2:05 PM, Kirill Taran <kirill.t256 AT gmail.com> wrote:Cedric and Pierre,
> In fact, that's were the magic happens: you must compile B.v
> (which is in the physical path "./A/") onto the logical path "A."> coqc -I A -as A A/B.vThat is solution! Thanks.
I had compiled B when I was writing here, but I did it with plain "coqc A/B.v".
Now everything is clear, thanks.Sincerely,
Kirill TaranOn Thu, Jul 24, 2014 at 12:28 PM, Pierre-Evariste Dagand <pedagand AT gmail.com> wrote:> I tried to do simplest project with possibility to access modules viaHave you compiled B first?
> dot-notation:
> $ mkdir A
> $ touch A/B.v
> $ echo "Require Import A.B." >> C.v
> And I try "coqc -I A C.v", "coqc -I A -as A C.v"
> and "coqc -R A A C.v", but without success.
In fact, that's were the magic happens: you must compile B.v (which is
in the physical path "./A/") onto the logical path "A." (the jargon is
defined there [http://coq.inria.fr/distrib/current/refman/Reference-Manual016.html#sec568]).
To do so, you can either use :
# Non-recursive import
or
coqc -R A A A/B.v
# Recursive import
Then, you simply compile C.v in the current physical and logical path:
coqc C.v
generated for you.
Cheers,
Pierre
.../Sedrikov\...-----
Cédric AUGER
- [Coq-Club] Dot-qualifying, Kirill Taran, 07/24/2014
- Re: [Coq-Club] Dot-qualifying, Cedric Auger, 07/24/2014
- Re: [Coq-Club] Dot-qualifying, Pierre-Evariste Dagand, 07/24/2014
- Re: [Coq-Club] Dot-qualifying, Kirill Taran, 07/24/2014
- Re: [Coq-Club] Dot-qualifying, Cédric, 07/25/2014
- Re: [Coq-Club] Dot-qualifying, Vladimir Voevodsky, 07/25/2014
